Group buy FM Chassis brace (finished) Fitting day organised!
- Mactype
oh you'll have no problems with the frame rails denting once the FM rails are fitted, you'll be able to just slide over most anything I'd say.
Clearance on my car wasn't an issue and I've no rattling so far, appears you can run quite small clearances between the cat and the brace too. This will alter depending on what cat your running and where that sits.
It does tighten things up quite a bit and lessens the creaks and groans in the chassis so all in all quite a good thing I feel.
Lotus Exige
Hi Darryl. This is Tommy. My car is good to go. I've pre-checked the seat bolts and all of them loosened without any dramas.
Unfortunately, I have a pretty jam packed weekend coming up. I have to work 1/2 of saturday and all of sunday, so will only be available sat arvo from about 3pm and sunday from about 5pm.
Oh, and I'm free tomorrow night if you're keen!
Eric, how did you go with Mania?
- Mactype
- marcusus
- marcusus
