Group buy FM Chassis brace (finished) Fitting day organised!
- Mactype
Ok lads, we're getting together on Saturday at my place in Kellyville to fit these. Bring your own tools if you want although I have most stuff needed.
I've only got one set of 4 chassis stands - and would be good if we can get 3 cars being done at once. so if you have some bring em.
Happy for anyone interested to come along - Say we start at 9am - PM me for the address.
Lotus Exige
- Alex
- marcusus
- Alex
marcusus wrote:Looking forward to this. Not so keen on the 9am start though now. I worked til 3am last night, so I'm a bit sleep deprived. Hopefully I'll be able to catch up enough on it tonight to be fresh tomorrow morning.
meh don't know what your complaining about, I just started work and finish at 8am, then need to drive straight there basically (need some petrol first)
- Alex
Yea I had to get some sleep which is why I didn't get mine installed
on the way there it was getting hard to engage first then reverse to get out of the driveway, I thought it might go away, or not
ended up being stuck in 2nd gear most of the way back and drove the car straight to mania (with some difficulty) slave cylinder was gone
But they had a replacement on hand so i ended up getting home by 2:30pm
and now i'm back at work
I guess Marcus got the height fixed up before the end of the day as well ?
- marcusus
SM wrote:I guess Marcus got the height fixed up before the end of the day as well ?
Haha. Yes. Adjusting the height was the easy part. The thing is that the car is now tracking slightly to the left after the height adjustment. I wonder whether there's a bit too much of a difference between the left and right heights, or whether it's just the alignment playing up since the height has been changed...
As for the brace, the first thing I noticed was the ride quality. It's so much smoother now. Just feels like I'm in a sedan with sports suspension. Cornering wise, it's stiffer too. I can take some of my usual corners at a higher speed. There's no real change to the handling dynamic of the car in terms of a change in over or under steer which is a good thing. The extra weight is not noticeable at all either.
Will make further comments during the week when I've dríven it more.
- Locutus
- Alex
Locutus wrote:how much ground clearance do you lose with the extra bracing? do you know if the rails & bracing were designed to withstand the occasional scrape over evil speed humps & whatnot?
from looking at Darryl's the centre of the frame sits higher than the chassis rails so as long as there is nothing sticking up in the centre there should be no clearance problems
also I'm sure they hold up alot better than exposed chassis rails on the car which seem to be very thin
