Hi Guys wheres the ignitor plug on an ignitor coil pack. We are wanting to
crank the engine without any ignition, in order to pump oil through newly
installed turbo. Any ideas, help, tips appreciated.
Novice1 aka Ron
Unplugging ignitor on NB
- Novice1
- Boags
BUMP! Come on guys, who knows?
I know Neil D did this for my NA6 when we did a compression test. I couldn't help Ron with the NB8A though.
How is everything else Ron?
- Boags
Okibi wrote:Couldn't you just plug the coils at the back or pull the leads off the plugs?
I've heard this fecks the coil pack. It might have been misinformation or a myth...
- Novice1
re ignitor
Hi Boags:
The time is 811pm and Andrew and my son are still working on the car.
Still no word from Andrew ( moderator ) re info to crank over the engine,
but thats Ok as we still have some way to go.
Cheers Novice1 aka Ron
- Boags
NMX516 wrote:Why not just pull the leads off the plugs??!!
Again, I've heard this fries the coil packs. I'd rather not recommend it just in case.
Can anyone confirm?
What are they working on Ron? Are the manifold and coolant lines in place?
- Steampunk
I found a plug that looks like the same igniter plug on an NA, but it's too far away (approx 12cm, sitting at the back-end of the intake plenum) from the coil-pack for my liking.
Fatty's idea might work, anyone please confirm?
Can someone also confirm if unplugging the plugs on the back of each of the two coil packs is ok for what we are trying to achieve?
Boags'MX5 wrote:NMX516 wrote:Why not just pull the leads off the plugs??!!
Can anyone confirm?
- sabretooth
- Novice1
Hi Boags:
Manifold and coolant lines are in place. My son and his mechanic friend Papu are coming over today to finish off the install.
Only thing I am concerned about is the closeness of the coolant hose that
sits beneath the turbo. Gotta figure away to get some clearance there.
Special thanks to Andrew (1RED5), Geoff ( Boags ), my son and his friend
Papu. My wife special , special mention for giving me the time to tackle this project and feeding us. And of course my parents for having me.
