fuel lid
chatchat
fuel lid
Postby chatchat » Mon Apr 21, 2008 1:16 pm
It cannot fit into my 2002 titanium version, want to find out what model it's for. The base ring is kind of same height all around.
Postby Hammer » Mon Apr 21, 2008 2:51 pm
I have an SP (2002) which came with the genuine Mazda chrome lid as standard, and yours looks the same to me.
Maybe it's for an NA. But I thought the NA fuel lid is slightly curved. Maybe it's not.
MINX
Postby MINX » Mon Apr 21, 2008 3:28 pm
Dont know if this will help. This is mine on 2004 SE.
Richee
Postby Richee » Mon Apr 21, 2008 3:29 pm
It looks round to me so therefore I think it is an NA lid
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
Postby Hammer » Mon Apr 21, 2008 11:55 pm
Here's the lid to my NB8B, and it looks similar to yours.
I know this might be a silly question (I didn't want to assume), but which side did you have the lid hinge when you tried to fit it? Towards the front of the car or the rear?
chatchat
Postby chatchat » Tue Apr 22, 2008 8:44 pm
actually the shape is fine, the only thing is the base not fit into the car, will be 1 side up 1 side down when I put in lid in.
Postby bruce » Wed Apr 23, 2008 4:34 pm
Silly question - is it for a 5?
stevesports
Postby stevesports » Wed Apr 23, 2008 4:57 pm
that's a good point. It does not look circular in that picture. It looks like it is actually oval in shape.
Postby Hammer » Wed Apr 23, 2008 9:56 pm
The insides of the lid looks like its for the 5, and the one on my NB8B is not pure circle, more ovalish in shape.
It's could be the position of the lid (ie. orientation)
chatchat
Postby chatchat » Sun Apr 27, 2008 7:09 pm
I think these photos could explain a bit more......
Craig
Postby Craig » Sun Apr 27, 2008 7:20 pm
Does it sit flush when you remove the 3 mounting bolts? :?
chatchat
Postby chatchat » Sun Apr 27, 2008 7:29 pm
the bolt positions fit perfectly.
Craig
Postby Craig » Sun Apr 27, 2008 7:32 pm
No what I mean is, when the 3 bolts are physically removed does the fuel cap sit flush and level with the car then? The pics you've posted shows it sitting uneven but the bolts are still in there. :)
Gazbo
Postby Gazbo » Sun Apr 27, 2008 8:02 pm
I bought one of these for my NA from MX5Parts.co.uk.
As delivered, the bracket was bolted on 180 degrees the wrong way.
If you unbolt the mounting bracket, rotate the bracket 180 degrees, then re-attach to the lid, it may fit.
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
JBT
Postby JBT » Sun Apr 27, 2008 9:55 pm
Gazbo wrote:As delivered, the bracket was bolted on 180 degrees the wrong way.
That's what looks to be the problem here.
Users browsing this forum: No registered users and 153 guests
