Sasso wrote:meanmx wrote:mattywood wrote:Sasso wrote:The good turbo options at the moment are something like this:
AVO mania prices: GT2560R turbo (200sx)
NA6 stage 1 105wkw 5-6psi $4730
NA6 stage 2 134wkw 11psi $6050
NA6 stage 3 151wkw
NA8 stage 1 similar pwr as nb8? $5600
NB8 stage 1 122wkw 5-6psi (close to what op wants) $4700
NB8 stage 2 153wkw 11psi $6050
How do these at the wheel Kw stats compare to the factory at the wheel outcome? Are the numbers quoted here at the fly wheel or the wheels? http://en.wikipedia.org/wiki/Mazda_MX-5 This will help me understand how much extra grunt I'd get.
These figures are at the wheels. Hence the wkw (wheel kilowatts) after the figure or rwkw (rear wheel kilowatts). I think drivetrain loss is about 30% (please feel free to correct me if I am wrong) which would mean a power figure of 100rwkw is roughly 150kw at the flywheel. Most people use wkw figures because they are easy to measure on a dyno whereas flywheel figures need to be measured on an engine dyno which means pulling the engine out. Hope this helps you out
Ben
Wow its not 30% loss. Its about 10% + 10hp for cars under 250hp from memory, I'll double check tomorrow. So 100kw is like 117kw at the flywheel.
Sasso wrote:Mattywood, have you made any decisions yet?
Sasso wrote:
55kw is pretty low for an NA but you have to take into account the dyno accuracy, and also the fact that NA's are almost as old as me, most cars that have been dyno'd would have 100km+, surely that would affect the results.
Also where are you getting the whole most NA's dyno at 55wkw data from?
Not that its that important but isnt the NA6 rated at 86fkw?
Boags'MX5 wrote:There is a VERY well sorted NA6 for sale on the forum at the moment. Search for "lowmiata".
