Thanks heaps for not listening to what I have said.
You can thank me when I am right.
Help needed tonight, Alarm backup battery?
- Alex
bruce wrote:Thanks heaps for not listening to what I have said.
thanks, and I think your too far away for me to be listening to you so I just read your posts instead
bruce wrote:Battery is definitely inside the siren. You can either buy a straight siren or one with a battery backup. I'm 'guessing' the siren is just a dumb device so you should be able to buy one off the shelf.
yes the battery is located inside the housing, but it's not just a dumb device it also had the shock sensor and ajustment dial inside the casing
bruce wrote:Remove one of the battery cables. All the lights should die and only the siren will sound.
no need, there is a test position and as stated already it just wails to death in a few seconds
and on another note, currently looking at making a replacement, should be done in 2 weeks or so since I couldn't find an off the shelf replacement
- Alex
- TieNN89
