Hardtop hanging wall mount
PASHN8
Postby PASHN8 » Mon Apr 21, 2008 6:30 pm
Hey guys,
Where can I get some sort of bracket/mount that will allow me to mount my hardtop up on my garage wall out of the way?
Mazda UK has something like this:
Half way down this link:
http://www.mazda-accessories.com/acatal ... yling.html
Anyone got something like that or know where I can find it?
D.
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Fatty
Postby Fatty » Mon Apr 21, 2008 7:34 pm
i think mania sells something like that
Postby Okibi » Mon Apr 21, 2008 9:58 pm
I'm sure bunnings would have hooks you could make work ..
Or (thinking out loud .. on a keyboard) you could get 2 more Frankenstein bolts, bolt them to a bit of metal and then bolt that to the wall.
Then i'd use a ratchet strap setup to make sure it can't get knocked off the wall.
PASHN8
Postby PASHN8 » Mon Apr 21, 2008 10:20 pm
Fatty, they have a rolling stand thingo, not a wall mount from what i've seen?
Okibi, more than just a pretty face huh? :) Only problem with that is the measurements would have to be spot on and it would also be quite a intricate procedure to line the bolts up when two people are trying to mount it.
- 2005 MX-5 SE
Postby Okibi » Mon Apr 21, 2008 11:36 pm
You could buy my Triumph Spitfire, it makes a great Hardtop rack :mrgreen:
If I was building my own magical hardtop storage rack, i'd be more inclined to make something that hold the hardtop similar to the floor mount but to use on the wall.
Say something that sticks out of the wall like a table, you sit the hardtop on that, strap it in then hinge upwards so the top sits vertically and takes up less room.
If you wanted to be cool you could use some car boot gas struts to slow the rack as it lowered the hardtop back to the \"table\" position where the hardtop sits like it was on the car.
Postby Okibi » Tue Apr 22, 2008 12:06 am
Here's a very quick sketch.
I recon it could be even better if you didn't have to sit the hardtop the right way up onto the \"table\" section.
Even better if it was a snug carpet lined fiberglass \"pod' you snuggly sat the hardtop into and folded away. Perhaps with a key lock so that it could be used in a carport and no one could steal your top. (Dynabolts secured from inside the pod to the wall)
Postby fastfreddygassit » Tue Apr 22, 2008 12:08 am
I keep mine in the spare room.....but that doesn't help this thread does it?? :mrgreen: :mrgreen:
Postby Okibi » Tue Apr 22, 2008 12:10 am
If you had a bunk bed then you could stick the hardtop above you (4 poster bed romantic stylin') and rent out the spare room to a female Swedish beach volleyball team.
Postby Okibi » Tue Apr 22, 2008 12:27 am
wun911
Postby wun911 » Tue Apr 22, 2008 12:13 pm
I have never seen FFG use the hardtop. And its silver in colour isnt it?
every ounce counts
Ajay
Postby Ajay » Tue Apr 22, 2008 11:03 pm
PASHN8 wrote:Fatty, they have a rolling stand thingo, not a wall mount from what i've seen?
yeah no wall mounts.. have the hoist from the roof thats pretty cool :)
nice design Dave!
Postby Hammer » Wed Apr 23, 2008 12:41 am
You can also use a wire and pulley system (hoist set), and have the hard top hanging from the garage ceiling above your 5.
This way, it can also be a one-person operation, without the fear of dinging your bodywork.
Steampunk
Postby Steampunk » Wed Apr 23, 2008 9:13 am
I was thinking the exact same as Hammer. I've thought about the design and it looks easy to rig up.
But as to wall mount hooks, there are also hooks made to hold bicycles on walls that might do the job.
Postby Mr Morlock » Wed Apr 23, 2008 10:29 am
I had a look at the UK brackets- these co's sure know how to charge- crazy price. The ceiling is a good bet if you have the height & beams for support. Bunnings for one certainly has brackets and these could be anchored to the brickwork. If you prefer to make your own - angle iron is easy to work with and if you cannot weld it yourself a mate or the local pro welder will do it in a blink. Spray paint to make the bracket look good & rubber tube for scratch protection.
Postby Okibi » Wed Apr 23, 2008 11:42 am
Yup been loads of threads about how to make a hardtop hoist.
Users browsing this forum: No registered users and 143 guests
