Patchy's Fawlty Towers risk management. Enter at own risk
ampz
Vehicle: NA6 - Turbo
Postby ampz » Mon Apr 07, 2008 7:59 am
Huh?
StanTheMan
Postby StanTheMan » Mon Apr 07, 2008 8:07 am
I'm not a Carbon Fibre fan......but id does look better than the chrome.
On another Note.....I've got to get those stands back to you too ampz. :mrgreen:
PM me your adress.
Sean
Postby Sean » Mon Apr 07, 2008 5:56 pm
StanTheMan wrote:cheers Sean.....Don't stress though :mrgreen:
No stress mate, just gimme a yell if you can use it.
Craig
Postby Craig » Mon Apr 07, 2008 7:11 pm
jules wrote:I'd go a later model. Craig knows all about them..
Too right! 8) :lol: :oops:
StanTheMan
Postby StanTheMan » Fri Apr 18, 2008 12:36 pm
Got bore today so I decided to raise the rear suspension in the pooring rain
gees that took all of 20 min
took me almost as long to resize & upload the pics :lol:
after
needs to settle a bit. Now need to take it for a drive 8)
Hot Rodders
Postby Hot Rodders » Fri Apr 18, 2008 3:18 pm
:shock: Is that the rear spring settler on the ground behind the car?
Evo, Its not a Dirty Word! Good As Gold.
President Bendigo Gliding Club
www.bendigogliding.org.au
StanTheMan
Postby StanTheMan » Fri Apr 18, 2008 3:40 pm
I just came back from a little drive the rear has setlled
Here you can see the shock with the cup that holds the spring. The cup is held in place by a clip. Just below the cup you can see a grove which is the lowest setting.
It is now at the higest setting. So all i did was force the cup higer & moved the circlip to the highest setting. To lever it I used the handle from the sledge hammer. Rather than taking out the whole shock , take the spring off , move the circlip & then put it all together again.
so this is how it now looks with the suspension settled back into place. Thats about 8mm extra travel before it starts to hit the bumpstops.
It may be just my mind but I did the front a few months ago. so maybe I aslo mucked about a little with the ballance of the whole car.
It appeared a little more stable even though its now higher but its defenatley a little better over big bumps
AJ
Postby AJ » Fri Apr 18, 2008 5:45 pm
you still haven't given craigs roof back :lol:
XMX5 Rogues
StanTheMan
Postby StanTheMan » Fri Apr 18, 2008 6:15 pm
There has been a No of attempts. I guess he's busy tonight.
marcusus
Postby marcusus » Fri Apr 18, 2008 7:34 pm
StanTheMan wrote:pooring rain
As compared to the riching rain? :P
sabretooth
Postby sabretooth » Sat Apr 19, 2008 10:51 am
Did you do that without removing the shock assembly from the car?
Craig
Postby Craig » Sat Apr 19, 2008 11:22 am
AJ wrote:you still haven't given craigs roof back :lol:
I'm getting it back tonight hopefully! :mrgreen:
StanTheMan
Postby StanTheMan » Sat Apr 19, 2008 12:10 pm
sabretooth wrote:Did you do that without removing the shock assembly from the car?
Yes I did. I also used a crow bar to push up the cup evenly.
Craig
Postby Craig » Sun Apr 20, 2008 6:01 pm
I got my hardtop back today...looks a little red though! :shock:
Postby Okibi » Sun Apr 20, 2008 6:10 pm
Craig wrote:I got my hardtop back today...looks a little red though! :shock:
:shock: Over spray? :shock:
