Negative bling
- Andrew
- TieNN89
- sliq
- rain902
- CheyneX5
Negative bling
The link to me simply looks like a black plastic injection moulding with pressed metal bracketry attached. The supplier should readily be able to tell you what is the material. The suggestion about painting chrome is to be avoided. It is very hard to get good adhesion and durability as the surface is so smooth. Even chrome plating of plastic is a challenging process - achieved with plating grade plastics and very carefully controlled mouldings to avoid stress. Apart from appearance I could not really see any purpose in a CF construction for a petrol cap.
- rain902
Negative bling
Mr Morlock wrote:The link to me simply looks like a black plastic injection moulding with pressed metal bracketry attached. The supplier should readily be able to tell you what is the material. The suggestion about painting chrome is to be avoided. It is very hard to get good adhesion and durability as the surface is so smooth. Even chrome plating of plastic is a challenging process - achieved with plating grade plastics and very carefully controlled mouldings to avoid stress. Apart from appearance I could not really see any purpose in a CF construction for a petrol cap.
which link? the UK one is not injection moulded plastic with pressed metal bracket attached, you can examine it this sunday if you wish to...
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
Negative bling
It certainly looks like it to me. 2 mouldings ring and lid and bracket(s)probably hinged with a roll pin and spring and mounting screws. If it is not plastic it merely demonstrates that the picture and description are inadequate.
- meanmx
Negative bling
Mr Morlock wrote:It certainly looks like it to me. 2 mouldings ring and lid and bracket(s)probably hinged with a roll pin and spring and mounting screws. If it is not plastic it merely demonstrates that the picture and description are inadequate.
Looks like metal to me
Ben
2014 VW Mk7 Golf R
