a) use a syringe or turkey baster to try and suck out the old oil. This should eliminate any spillage that will occur. It is not necessary to suck it out and replace it but it is recommended. I would have thought that a place like Mania that specialise in Mx5's would do this but you would have to ask.
b) You can either remove the plastic cover or keep it on depending on what you prefer. I kept mine on as it gives a fuller look to it. It will slip on over the top but it will generally be tight as well
c) The handle is attached by glue. You need to break the seal that the glue has. All I did was grip it and twist and that was enough to get it off. After the glue seal has been broken it comes off fairly easy
Ben
Handbrake + Gear knob Gaiter/Boot install
- meanmx
2014 VW Mk7 Golf R
Mazda make nice aluminum hand break goes well with voodoo knob.
(voodoo hand break is nice but hard to find and I dont think comes with button)
Silicone is a good adhesive for new hand break
Only problem is aluminum hand break is about 7 grams more than stock plastic one.
You might like benny's boots, very soft leather nice to touch.
BTW if you are 6spd NB8B you dont need the turky baster...
every ounce counts
