Look what I've done :(
- AB7
The LHS of my frame had been making lots of noise lately.
I was trying to tighten the bolt...then SNAP!!!
Any idea on how to fix it? The other side of the bolt seems to be welded to the frame.
Hi there, I would grind the welded section off. If there is enough of the bolt left on the welded side get some vice grips on and remove otherwise you will need to drill a small hole in the bolt and get hold of a suitable Ezyout (any tool shop) and use this to remove the piece.
I note that these bolts only tighten up a certain distance (see thread length) and therefore can't be tightened up.
Trust this helps.
Trust this helps.
Make something idiot-proof, and somebody will make a better idiot.
2007 Limited Edition (back in the saddle again)
- AB7
- ampz
- Vehicle: NA6 - Turbo
If u drill out the bit left in and just put a bolt in it will be floppy and noisy/rattly as before if not worse. The only poper way is to get one of the special bolts and replace as stated above. I know it means getting the vinyl off/away from the frame but it is the proper way.
- Garry
Isn't the nylon sleeve supposed to stop it from rattling around?
The rooves in both of my MX5's used to rattle at the pivots, especially when the roof was down. I added a few turns of fine fishing line to pad out the gap in all the pivot points and all the rattles from the roof stopped. Bliss and happiness.
- AB7
AB7 wrote:I may be even contemplating of getting second hand frame.
Do you know if NA & NB frame interchangeable?
The frames are certainly interchangeable .. if you have a rollbar there could be some issues
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
Users browsing this forum: No registered users and 155 guests
