12 volt outlet NB8A
12 volt outlet NB8A
I want to tap into the rear of the 12 volt outlet to provide a second outlet for my GPS. Does the outlet just pull out?
Job done and it was easy.
Firstly remove the small tray next to te 12v outlet, it pulls out by the bottom lip.
Then remove the 12v outlet by twisting and pulling as it does have locating lugs.
The yellow wire is the positive, and simply solder extra wires to the yellow and black wires and run them back through the console to beneath the glove box.
BIAS boating have a nice under dash mounting twin outlet (part no. 8316)that screws up onto the steel rail beneath the glove box door.
hope this helps
hope this helps
Users browsing this forum: No registered users and 117 guests
