Hi Guys,
I'm about to install Hydra nemesis ECU on my NB8B.
The harness is pretty straight forward, and the MAP sensor pick up is from the 'nipple' on top of the intake manifold.
Other than that, is there anything that I should worry about?...Do I need to disconnect the battery for precaution?
Cheers.
Hydra Nenemis installation?
- AB7
- PASHN8
AB7, non-turbo MX-5? Did the Hydra come pre-loaded with the base map, as from my knowledge it is a standalone ECU yes?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- blackster
AB7 wrote:Yep mine is non turbo. Hydra is standalone ECU, they can handle SE or SP as well. Quite a lot of people are using it for their Miata MSM in US.
Yes they are number being used by MSM users, whether they have issues or not is questionable. Has hydra set up shop in aus to offer support? I ask because when i enquired about it there was no local support or intention of it.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
