stock head gasket thickness?
- 16bit
just wondering what the stock head gasket thickness is? and if I was to change it to a 0.8mm one would the compression ratio go to in a nb8a 9.5comp motor?
- mazlot
- AJ
mazlot wrote:won't make a bees fart in a cyclone difference to your compression ratio.
Depends how many are in there now
true.......we once tried decompressing a holden 6 we'd turboed by using 3 repco gaskets.........that ended in spectacular fashion..........LOL
XMX5 Rogues
- irwin83r
the mazda factory gasket i was given (got from mazda spares) looks like its about 1mm thick. so your only going .02 of a mm which is .00078\" i hear a 0.020\" head shave makes a .5 comp increase so yeah.. not going to be huge gains. ill get a Micrometer from work and measure the standard one properly tonight if i remember.
cheers
cheers
- Sean
- 16bit
- Benny
Why not turf the gasket all together and get the head and block O ringed?
You can then run high boost and not worry about blowing head gaskets.
In my nefarious youth, I had a turbocharged Commodore that kept blowing head gaskets because I wanted to run high boost (21 lbs), and not so low compression.
Got the head and block O ringed, and never had a problem with it ever again.
Mind you, my transmission expert and me were unable to make any Turbo-Hydramatic 400 box last more than a few months, but that's another story.
