aluminium flywheel torque settings
anyone with aluminium flywheels, what torque do u set the flywheel bolts at? its for a 1.8 1995 mx5
- CT
- CT
- fattima
Also can I add check the thickness of the flywheel where the bolts go through and make sure it is the same as the old one. I used an alloy flywheel on an engine and the bolts bottomed out but felt like they had torqued up. Funny noise on the engine dyno and flywheel lets go on the run down, damaged the block as it came off and left a nice graze in the dyno room wall
This was not on a mazda engine, but can't hurt to check.
