If you get 4 extra injectors welded into the intake runners then it'll be alot better for tuning cause you can control the stock set much easier at low opening times, extra set kicks in when needed.
Sure hope your not thinking of running those 4 injectors along the piping, that'd be really dodge, plus the fuel doesnt get atomised enough/properly
AVO 1.6L - How much power did you make?
Boags'MX5 wrote:marky210 wrote:With the turbo link you can run up to 4 extra injectors which is what im gunna be doing on my Nb8a![]()
Why don't you just run bigger injectors?
Hey Boags
The Link turbolink ECU only controlls the extra injector or 4 if you choose to have them plumbed in but not the stock injectors. As sson as the car comes on boost it runs the extra injectors. The stock injectors still run off the stock ecu.
Yeah Sheck, Im going to get them welded into the intake plenum
Mark
99 mx5, Brilliant Black with hardtop, cusco f/brace,intake and AVO turbo kit awaiting install.Tien SS coilover kit,BD Rollbar,16x7 Work Meister's!!
Blue94t wrote:AVO's dyno has always had the reputation for reading higher figures than most.
A few people have found that when run back to back with other dyno's.
Jake
Hey Jake
I also had the car on other dynos and the figures were fairly consistant
But yeah can understand that dynos do vary.
Cheers,Mark
- Boags
marky210 wrote:The Link turbolink ECU only controlls the extra injector or 4 if you choose to have them plumbed in but not the stock injectors. As sson as the car comes on boost it runs the extra injectors. The stock injectors still run off the stock ecu.
Fair enough. I'll trundle back to the told corner.
Boags'MX5 wrote:marky210 wrote:The Link turbolink ECU only controlls the extra injector or 4 if you choose to have them plumbed in but not the stock injectors. As sson as the car comes on boost it runs the extra injectors. The stock injectors still run off the stock ecu.
No need to be so harsh on yourself Boags
Mark
- Boags
marky210 wrote:Boags'MX5 wrote:marky210 wrote:The Link turbolink ECU only controlls the extra injector or 4 if you choose to have them plumbed in but not the stock injectors. As sson as the car comes on boost it runs the extra injectors. The stock injectors still run off the stock ecu.
No need to be so harsh on yourself Boags![]()
Mark
Sorry, should have used an emoticon.
