Sportmax 002's ?
Blue94t
Postby Blue94t » Wed Mar 26, 2008 8:22 am
Green Comet had them on his NA.
Only sold them recently. I think he imported them himself.
Jake
stevesports
Postby stevesports » Wed Mar 26, 2008 8:54 am
yep they look fantastic, however i remember him saying that it adversely affected the handling and performance of the car.
green_comet
Car Detailing Guru
Postby green_comet » Wed Mar 26, 2008 9:49 am
Yeah they looked really tough on the car, but the handling went to sh*t. The car would under steer all the time, and also it was extremely hard to get rid of all the scrubbing.
The 002's also stick out the sides by about an inch, soo you will need flares to keep the police away. Too much work to do right, and at the end of the day your stuck with an MX5 that looks cool but wont handle like an MX5. I was alot happier when I went back to higher offset wheels.
Here what my car looked like, you can see the rear wheel how far it sticks out..
PS. don't waste your time and money.. :|
green_comet
Car Detailing Guru
Postby green_comet » Wed Mar 26, 2008 11:21 am
I was using a 195/50 15 stretched onto 15x8 0 offset.. The yank guys dump their cars very low, roll/stretch their guards, and run crazy camber to keep them from rubbing.
They guys in America use them as 002's are very cheap in USA, something like $300 a set..
There are also problems with wheel strength, being soo cheaply made they tend to fall to bits instead of bending like a good wheel would.
As for handling, the car felt like it was a fwd when cornering hard, turn in was terrible, and having no power steering in the clubman made life harder.
wun911
Postby wun911 » Wed Mar 26, 2008 11:45 am
Those pics are shoking how could they name such a wheel \"sportmax\"
every ounce counts
Adam_NAclubman
Postby Adam_NAclubman » Wed Mar 26, 2008 7:28 pm
wun911 wrote:Those pics are shoking how could they name such a wheel "sportmax"
You have to remember though that the guys that use them over there like them because if they hit something with the wheel and damage it, they have another one at their door two days later for $100. It'd cost at least that much to repair a bent rim here, so its probably not that big a deal that they break rather than bend. Unless you live thousands and thousands of kilometres away where it costs heaps to get a wheel sent over.
I'm looking at the 949 6UL's atm, I think they look like arse but I still want a set
Adam_NAclubman
Postby Adam_NAclubman » Wed Mar 26, 2008 9:49 pm
That car looks good, the 6UL wheels look like Australian wheels though. But the sizes they're available in are appealling.
Sheck
Postby Sheck » Fri Mar 28, 2008 1:08 am
gotta remember that broken rim was from hitting a curb while drifting, alot of aftermarket wheels will do that, probably moreso with thte expensive ones cause to get light weight they need to forge which means brittle (correct me if i'm wrong there). I think only steeleis would bend if you hit a curb sideways at say 50-60km/h
But yea big camber and big fender pulling is what they do, also running 195/50's on the 8 inch rim is what most of the drift guys in the US do to run those wheels.
I'm running +9 - lets say +10 offset rims and i love the handling, wayyy better than stock offset. You just need to get your alingment right, and suspension set up, no point running stock shock spring combo with majorly different offset wheels and weak camber numbers..
Sheck
Postby Sheck » Sat Mar 29, 2008 12:12 am
ther will be pics on this site somewhere, its the cammo drift pig.
I only run re001 on front and kumho spt on back, still really grippy
RaYmO
Postby RaYmO » Sat Mar 29, 2008 12:18 pm
the 949s are light and do come in great sizes... but they just look like something out of bob jane's workshop :?
Boags
Postby Boags » Sat Mar 29, 2008 1:28 pm
Sasso wrote:No one likes the 6UL's? I quite dig it. Its similar to the new weds sport wheel and enkeis.
I like them... :D
Blue94t
Postby Blue94t » Sat Mar 29, 2008 1:59 pm
I like the 6UL's
15x9s for me please
Adam_NAclubman
Postby Adam_NAclubman » Sat Mar 29, 2008 3:00 pm
I'll be getting the 15x9's soonish I think, once I've recieved some other goodies I'm ordering.
I'm finding it quite hard to find some decent photos of NA's with the 9's to see just how they sit though
Blue94t
Postby Blue94t » Sat Mar 29, 2008 11:41 pm
Adam,
From what i have read and been told by 949 racing you will need to flare your guards to run the 15x9's. They will not clear even if your guards are lipped.
Thats ok though, I love flared guards :D
Adam_NAclubman
Postby Adam_NAclubman » Sun Mar 30, 2008 12:55 am
On their site it says you just need rolled guards to fit them unless you go for stupidly wide tyres. I'd only need an extra 6mm on the outside compared to my 7\" +17's so I think a heat gun and repeated use of a guard roller might be enough to pull the guards enough, so I'll just hold off getting my car painted till thats all sorted. Not that I was looking at getting it painted on any useful timescale anyway. Flares would be nice but would kind of make it a bit obvious that I've increased the track waaaaay too much, and would look a little silly when running normalish wheels. They'd look tops with the 9's on though...
