SE Cooling Issues?
Craig
SE Cooling Issues?
Postby Craig » Thu Mar 27, 2008 11:39 am
Hi,
Noticed last night that when I got home I could hear a gurgling noise inside the cabin (water boiling sound), and as soon as I turned on the heater it went away. Whilst out driving the car was driving ok but certainly not at it's full potential, almost felt like the leads were a tad wonky. Radiator is full with water too. Car has done 60,000klms for reference. Temp gauge sitting at normal just to the right of middle as per usual.
When I left the heater turned on the car boosted to full potential, making me think that it's got a temp sensor that retards performance when too hot.
Anyone else experienced this?
Craig
Hot Rodders
Postby Hot Rodders » Thu Mar 27, 2008 2:37 pm
:mrgreen: Serves you right for getting rid of the Camel and getting involved with the SE thing!
Evo, Its not a Dirty Word! Good As Gold.
President Bendigo Gliding Club
www.bendigogliding.org.au
sabretooth
Postby sabretooth » Thu Mar 27, 2008 3:32 pm
Can you verify that the fans work OK?
Is the thermostat OK too?
Benny
Postby Benny » Thu Mar 27, 2008 3:35 pm
You might also have an air bubble in there somewhere, and when you opened up the heater valve, it may have gone away.
Craig
Postby Craig » Thu Mar 27, 2008 3:43 pm
sabretooth wrote:Can you verify that the fans work OK? Is the thermostat OK too?
Not sure re the fans/thermostat but it never shows it as overheating on the gauge, mind you it could be a dodgy one like the oil one.
Benny wrote:You might also have an air bubble in there somewhere, and when you opened up the heater valve, it may have gone away.
Possibly...I'll try it tonight with the heater off and see what happens.
Craig
Postby Craig » Thu Mar 27, 2008 4:33 pm
drifter wrote:Regardless of what the underlying problem may be. I would immediately replace the radiator cap and thermostat and check all hoses. Give the coolant a good flush - when coolant has over heated just once the anti corrosive properties become greatly diminished. Start from the basics and see if the problem still persists.
Good point Drifter, the basics are always the way to go, just ordered the cap and thermostat from our Spare Parts Dept...getting them tomorrow! 8) Can run for 1 more day with the heater on! :)
AJ
Postby AJ » Thu Mar 27, 2008 5:07 pm
& once you replace all the bits Craig, make sure to run it for a good 1/2 hr/40 mins with the radiator cap OFF & the heater wide open (not sure if NB's have a water tap for the heater or not :? ).......anyways, that should get rid of any air in the system 8)
XMX5 Rogues
Craig
Postby Craig » Thu Mar 27, 2008 5:40 pm
Shall do! 8)
Fatty
Postby Fatty » Thu Mar 27, 2008 5:48 pm
i don't know if this is relevant but i had to run with the heater on full at winton last weeend, otherwise the car would overheat. i recently replaced coolant , rad, rad cap, and thermostat too. maybe i need to depressurise the system and run the car for half an hour as suggested.
i will also be removing the aircon and fitting an oil cooler, hopefully this will solve it.
Postby Okibi » Thu Mar 27, 2008 5:49 pm
Put in a real gauge so you know what's going on.
AJ
Postby AJ » Thu Mar 27, 2008 5:51 pm
they shouldn't cause it fatty, honestly.........try running the engine with the rad cap off for 1/2 hr, it's always been SOP for me when changing, draining or generally fooking around with the cooling system in any car i've had.
XMX5 Rogues
Fatty
Postby Fatty » Thu Mar 27, 2008 5:59 pm
SOP ?
AJ
Postby AJ » Thu Mar 27, 2008 6:19 pm
ya gunna make me bloody type it aren't ya?? :roll:
Standard Operating Procedure :P :mrgreen:
XMX5 Rogues
Fatty
Postby Fatty » Thu Mar 27, 2008 6:30 pm
ah, that makes sense :D
thanks for the advice mate.
now have you gotten on to our mate about those wheels yet? is he a happy camper?
Boags
Postby Boags » Thu Mar 27, 2008 7:01 pm
Oi! I don't like this lovey dovey stuff between you two! It was much more entertaining when you were fighting. :mrgreen: :lol:
