Hi all,
As topic says, when i lock my car with the remote central thing it will lock the passenger side but it doesnt lock the drivers side door. When i look in the window i can see the passenger side lock ( the slide moes about 2cm towards the back of the car) and when i look at the drivers side the lock moves but only a tiny ammount (4-5mm). If i lock the drivers side by opeing the dopor pushing the slider then closing the door and holding handle out it will lock both doors and same with the key. the door will unlock using the remote. Ive tried spraying WD40 into the lock and where the slide is but no dice, anyone have some ideas? im not keen in trying to take the door apart or anything if it comes to that ill pay to get it looked at. I have a '90 NA6 with a Stinger locking system. Thanks for any advice, i miss my poor car cant drive it atm due to an unlucky rock to the windscreen
Remote locking wont lock drivers door :(
- Vehicle: NA6 - Turbo
- Steampunk
Mate don't be afraid to take the door skin off.
All you have to do is unscrew a few screws on the handle and latch and you simply pull it off as it's attached to the door frame via snap pins (or whatever you call them).
I had the same problem and it was a simple fix. The slider that connects the central locking mechanism to the lock came loose.
The central locking actuator works fine, but it simply has nothing to grab on to, hence it won't lock/unlock.
All that was needed was to tighten the 2 screws on the \"C\" clamp connecting the lock slider and actuator.
It's a little tricky to explain but just trust me, take your door-skin off and you will see how simple it is to fix.
Hopefully.
Hopefully.
- Steampunk
Thanks Red, problem solved i had a little trouble getting the door skin off i had one pin break out of the cardboard stuff, i looked at it threw the small gay and saw that it was cracking arround that pin before i put any force on it so im saying that was from a previous owner. ill post pics later for those interested. it was a \"clamp\" with 2 screws on it that needed sliding forward about 1 inch then retightened. Took me a few min to understand how the lock worked but like you said, easy fix
Thanks
Oni
Thanks
Oni
- Wuey
I'm having the same problem with the passenger door not locking. At first I though it as a bad battery voltage, then I thought it was too hard to lock (its harder than drivers side), but now that I've read this I'll check to see if its that screw. Thanks for that!
I would never have known it didn't lock until I opened the door and the alarm scared the crap out of me. Then to think I've been parking everywhere with effectively an invitation to open the door. Lucky no robbers spotted it, despite the alarm.
- sabretooth
Some cheap central locking actuators aren't watertight, meaning their insides rust and the actuation weakens. This will also cause the doors not to lock/unlock properly.
I was checking mine once to see why one of the doors wasn't locking. I started to remove the actuator, and after getting it off of its bracket tipped it to the side and let a stream of water out...
Yeah, that one went in the bin.
- Wuey
Users browsing this forum: No registered users and 86 guests
