I just went through this with my MegaSquirt.
Connect the AC line to the AC pressure switch (consult your wiring diagram). Also connect the condensor fan relay to this.
As for the tach, I don't know what that ECU accepts, but for my MegaSquirt I had to put a 1k resistor between the tach line and 12v for it to get a signal.
tacho wire
- sabretooth
- ampz
- Vehicle: NA6 - Turbo
- sabretooth
- sabretooth
- ampz
According to System wiring diagrams from Madracki system diagrams page 8
I would look at pin 2K on your harness (green/orange) for your tach sense to cluster.
Use it at your own risk though.
Huh?
