roll bars, 50mm clearance and tall people
Grumpy
Postby Grumpy » Tue Mar 18, 2008 9:11 pm
Have not heard that one down here Charlie Brown. As I mentioned earlier, ROPS is only required for club events, if it is called for in the sup regs. You can even run with a lap sash seat belt as well.
Sadly MX5 less for a while.
Rebuilding an 89 Honda CRX
CapitalF
Vehicle: NA6 - Turbo
Postby CapitalF » Tue Mar 18, 2008 11:31 pm
As Ive not been in an NA with hardtop can anyone tell me whether it is \"taller\" than the soft top? ie is there more headroom under a hardtop than a softop?
If so by how many mm approx?
Thanks
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
mazlot
Postby mazlot » Wed Mar 19, 2008 8:35 am
Peter,
drop by next Tuesday, you can fit mine on your car, to see yourself
Jeff
Farken Gruven
CapitalF
Postby CapitalF » Wed Mar 19, 2008 10:02 am
Thanks very much for the offer Jeff, but Im actually dropping off/picking up the car at Mikes at Daisy Hill (great service-his suggestion).
Another time, within the next few weeks would be great. I'll be in touch.
Peter
irwin83r
Postby irwin83r » Wed Mar 19, 2008 6:54 pm
Charlie Brown wrote:I have watch this discussion and I think that there is a major point that EVERYONE has missed.
If you have a standard MX-5 WITHOUT a roll bar you can now run in CAMS Super Sprint events.
What it means is that now I can run the NC in Super Sprints. :D Someone with a NA or NB without a roll bar can run. 8)
Fit a BD roll bar and not get under the 2” rule and you’re banned. :roll:
Work that one out!!! :evil:
not exactly
the 50mm requirement would be waived if a Mazda MX5 is fitted with a factory hardtop, although it is desirable to ensure the helmet is below the rollbar top.
desirable dosnt mean mandatory. and it also dosnt say 50mm bellow.. just not above
Return to “MX5 Motor Sport”
