Preset to max. 100Nm (74ft-lb), upon application will disengage at 100Nm (max).
Plastic sleeves prevent wheel rims from scratching
Rubber end stops prevent tops of wheel nuts from scratching
Remove the wheel nuts with full torque capacity from the Impact Gun. TLS Socket will unfasten to full torque delivery of the impact gun. Select from the range of TLS Impact Sockets.
To tighten wheel nuts, add TLS Socket to Impact Gun. Place socket on wheel nut and begin to tighten with Impact Gun. The socket will tighten wheel nut to max. 100Nm (74ft-lb), once this torque is reached the TLS socket will ‘slip’ and disengage the Impact Gun, preventing the wheel nut from tightening further, reducing the risk of being overtightened.
To reach the vehicle manufacturers torque setting (refer to the vehicles user manual), apply a Kincrome Torque Wrench to tighten to manufacturers specifications. Ensure the wheel nut is fastened securely.
Torque limited impact socket
- Andrew
Has anyone used one of these -
- Hammer
Sorry to hi-jack this thread...
... but has anyone had any experience with any $60-$90 electric impact wrenches? How good are they?
Impact Wrench
New. 1/2\" drive. 12 volt outlet connection. Includes two double ended sockets. Impact resistant housing. Blow moulded carry case.
Repco has the above on sale for $69.95, and I'm considering at getting one. Any particular feature and/or functionality that I should have as a must?
I'm looking to using it when I change over the wheels on my 5 from road to track wheels etc. Plus on odd occassion removing my 4WD wheels.
Any advise anyone?
Impact Wrench
Any advise anyone?
- godfather of saké
Okibi wrote:Ive used a snap on one that I was pretty impressed with, dunno if the cheap ones stack up.
Can the electric ones muster up enough grunt to say take off stiff suspension bolts etc?
- fattima
Good thread about various brands here
http://www.bmsc.com.au/forums/rallying-technical/13652-battery-rattle-gun-impact.html
Babalouie wrote:Okibi wrote:Ive used a snap on one that I was pretty impressed with, dunno if the cheap ones stack up.
I had thought same thing too untill we purchased a Hitachi cordless impact wrench. It has a lot of torque and enough charge for a full day's use on the RX-7 down at the race track. I would not purchase no cheapy to do it though. I am thinking of going Dewalt for myself which has a bit more torique than the Hitachi.
Back on topic - Snap On Tools also do a similiar thing
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=78290&group_ID=2219&store=australia&dir=catalog
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=12220&group_ID=1649&store=australia&dir=catalog
Users browsing this forum: No registered users and 296 guests
