RCA Cable route? PICS PAGE 3
- ducktape69
- Matty
I had mine down the pax side. On my NA there was a plastic tube under the door sill that can be split open to run cables through (just remove the sill trim and lift the carpet).
That gets it past the door opening cleanly, then there's a gap to push it through the LH tunnel and down to the boot. The amp was mounted vertically in the LHS of the boot. (Probably not easy to do this in an NB). The speaker wires were bundled and taped to the RCAs and the amp control line (blue wire) and fed through as one big snake.
- ducktape69
well i got it all done today...BUT the crappy RCA cable broke the head off it AFTER i had routed it through GRRRRRRR...and it was the best cable autobarn had...
oh well...new cable on the way tomorrow
BLECK 2002 Mazda MX5 NB8B. Custom Heatshielded CAI . KYB AGX's + King Springs. 17\" Bleck Rims. Custom BASSSS Install.
- ducktape69
finally got it finished today...turned out that 2!! sets of US Audio RCA cables were faulty from autobarn...
so went and spent $50 on some top end cables and turned out perfect
will post some pics later
- Ajay
- ducktape69
it definately looks amazing!
unfortunately i blew the main 40A fuse after about 10min of driving and cant really figure out why...
everything is connected correctly...
couple questions:
1. is it ok to have the earth for the capacitor and amp on the same screw(battery earth)
2. the amp is sitting on the spare tyre bolt that i used to secure the base for the amp...is it ok for the amp to be grounded like this?
grrrr...looks like the sub blew also...whats a good 10\"sub to buy?
couple questions:
- ducktape69
- Ajay
- ducktape69
- ducktape69
