AJ wrote:been a few years since i punted a car around Wakefield......an L34 replica it was
Turbo Girl wrote:Casey wrote:edit - Actually I think RussellB (Turbo Boy's owner) actually set FTD in Turbo Girl - a low 1.07 IIRC. But it wasn't recorded as the CoC allowed Russ to have one-off drive to confirm a handling issue with Turbo Girl.
Casey, sorry to correct you but Russell only got a low 1.09 to confirm my handling issue, since then I found out that I had 3 bent conrods!
mx5racing wrote:If memory serves me right the SP's were on slicks as well?
Craig wrote:AJ wrote:been a few years since i punted a car around Wakefield......an L34 replica it was
BOGAN ALERT
mx5racing wrote:just quickly, what are the prices on an import NC in good condition??
also how much harder/easier are they to get around in terms of removing the factory saftey devices (airbags, pretensioners ect) would you bother with the stability control (I understand alot leave ABS on their race cars)?
is there noticibly more room vertically (for cage/head clearance)?
are their any cooling issues (I hear NA and NB racers complaining often)?
how good is the mazda LSD for the NC, are their any alternatives yet?
how different is the actual seating position?
is it easy to get steering wheel boss's for the NC?
Ours start at around $20,000 landed.
SRS airbags and seatbelts are the same to remove as NB's - easy. The Jap RS spec ones also have side bags which come out with the seats. Would I remove them..... without a doubt. A hand hitting your face when the SRS goes off in a road car makes a mess. The same hand hitting a helmet or roll cage ..... ugly.
Jap softop ones dont have stability.
You sit quite low in the NC - even the road cars so the head height issue is not a problem. I'm 6 foot and have a comfortable margin.
NC's the 1st one I've dríven that didnt overheat. We've not had any issues at all yet but havent had a super hot day in full race conditions when you are right behind someone restricting your airflow. Due to the shape of the nosecone and the angle of the radiator the full core is exposed on the NC and Im sure this helps.
Diffs so far have been very good. Temps are very high (over 150 at Bathurst but we run the same oil as the Factory cars (courtsey of Allan Horsley). We are currently having some diff centres built and this should bring the temps down.
Seating pisition is the same just lower.
Steering wheel boss is the same as NA/NB.
Chris.
AJ wrote:like an alcoholic offered a glass of grandfather port...............if someone chucked me the keys to one, i'd be in like a flash
mx5racing wrote:Having had a chance to drive all of them, I can say the NC was the best overall straight out of the box. Our first time out at Oran Park we did 1.24’s on the big track in cars that had roll cages, and the trim stripped out and that was all.
Daz wrote:Like Gary points out, the SP is built on essentially a 10 y.o. platform now, I would hope they can improve it, if they release an MPS NC (assuming it will be in the 190kW range) I will be eternally jealous of all owners.
