Melbourne Dodgy Day - *Sat March 29th* NOTE NEW DATE
Victorian and Tasmanian Events
Moderators: Stu, miata, Andrew
Hot Rodders
Postby Hot Rodders » Thu Mar 13, 2008 9:19 am
Evo, Its not a Dirty Word! Good As Gold.
President Bendigo Gliding Club
www.bendigogliding.org.au
mekros
Postby mekros » Sat Mar 15, 2008 8:51 am
Sign me up, can I do a full fluid change on the day too? :roll:
Hot Rodders
Postby Hot Rodders » Sat Mar 15, 2008 9:11 pm
Should Be OK mekros!
1. Rodders
2. Wun911 (Installing coilovers to NB8B)
3. Green_Comment
4. Alfadog
5. Stevesports
6. Fatty
7. AB7
8. meanmx
9. FMS01
10.mekros
Unconfirmed
1. Andrew
2. Juffa (whos brakes can I stuff this time?)
3. Fattima
4. Jake
5.
6.
7.
8.
9.
Those who don't want to get their hands dirty and so are only coming for the food and drink Mr. Green
1. Fastfreddygassit
2.
3.
4.
5.
6.
7.
8.
9.
mekros
Postby mekros » Sun Mar 16, 2008 10:58 am
cheers,
Now I've got to start hunting down all fluids required.
mekros
Postby mekros » Thu Mar 20, 2008 6:13 am
Has anyone got a speed bleeder that they can bring along on the day? I want to do my brakes, and might as well do it efficiently :)
stevesports
Postby stevesports » Thu Mar 20, 2008 8:56 am
just wanted to confirm that i can borrow other people's car stands on the day so i can change box/diff fluid?
Fatty
Postby Fatty » Thu Mar 20, 2008 4:05 pm
steve i'm bringing 2 ramps for rod, so i guess you can use those to after he's finished with them.
meanmx
Postby meanmx » Thu Mar 20, 2008 4:39 pm
mekros wrote:Has anyone got a speed bleeder that they can bring along on the day? I want to do my brakes, and might as well do it efficiently :)
Hey Mekros. A speedbleeder is generally a replacement nipple that is kept on the car. These are designed with a ball bearing I think that doesn't allow air in, only fluid out. Unless you are talking about a bleeding system involving a cup in which case I find that someone holding the tube in some clean fluid just as good. Should be plenty of us there to lend a hand pumping the pedal :lol:
Ben
2014 VW Mk7 Golf R
wun911
Postby wun911 » Thu Mar 20, 2008 4:49 pm
Mekros speed bleeders cant be shared. Dont trust me with the break fluid and bring a few rags and a funnel.
I have 2 ramps and 6 stands.
I just need ramps when I tighten all my suspension bolts so I think your covered steve.
Who else is doing what so we know what stuff to bring...
every ounce counts
Fatty
Postby Fatty » Thu Mar 20, 2008 5:21 pm
wun911 wrote:Who else is doing what so we know what stuff to bring...
the way things are going, i'll probably be with fastfreddy hovering around the bbq and drinking beer, more than working on my car. i'll have a few little things to fix , but not much. most of the work will be done by then (before natmeet) .
mekros
Postby mekros » Fri Mar 21, 2008 5:26 am
ok no speed bleeders for me then :cry: So I'll just have to trust someone to help me bleed the brakes with me. 8)
Full fluid change for me, so that means clutch, brakes, diff, gearbox (anything else I missed)?
Cheers guys.
green_comet
Car Detailing Guru
Postby green_comet » Fri Mar 21, 2008 11:40 am
mekros wrote:Full fluid change for me, so that means clutch, brakes, diff, gearbox (anything else I missed)?
Engine Oil? Coolant?
wun911
Postby wun911 » Fri Mar 21, 2008 5:42 pm
I have some double distilled water has undergone reverse osmosis with milipore 8)
every ounce counts
mekros
Postby mekros » Sat Mar 22, 2008 9:29 am
oil was done, prior to me buying it, I trust the guy and the oil does have a nice honey colour to it.
Coolant I might try and do this long weekend, otherwise yes I have to get some too.
Cheers for helping my bad memory
Hot Rodders
Postby Hot Rodders » Mon Mar 24, 2008 1:03 pm
OK guys, this event is fast approaching. In fact it is this coming week end. If any one else is attending, could they put their name down ASAP as I need final numbers to do the catering for the BBQ. Also if any one needs the address, could they PM me.
After much thought, I will be charging a measly $5 a head to cover the cost of food and drink.
Only 5 more sleeps! :D
Return to “Victoria/Tasmania”
