HELP...Removing rear caliper.
- Jimmy
Im trying to do a basic brake pad change here and im stuck. I cant get the rear left caliper off. Ive followed all the stuff on miatanet like relaxing the hex bolt and removing the lower bolt but the thing is still stuck firm. Am i missing something really obvious? (handbrake is off)
- Jimmy
- Jimmy
Identical problem to andrew. Inside pad appears to be well, not there, while the outside pad has some meat to it. I guess its down to wd-40, rubber mallot and beer.
http://www.mx5cartalk.com/viewtopic.php?t=29626&highlight=seized+caliper
AJ wrote:drown both the rears in WD40 & walk away from them for the night
I did this for 5 successive nights with no joy. Took it to a brake specialist, and a couple of dollars later it was all free.
- AJ
Casey wrote:AJ wrote:drown both the rears in WD40 & walk away from them for the night
[smartarse off]Is this a problem for all NB's??............i only ask because maybe someone has come up with a reliable fix that could be posted for anyone who comes across it, & obviously the rears aren't working properly while they are jammed like this if one pad is wearing out & not the other??[smartarse on]
XMX5 Rogues
Sorry Jimmy. Just remembered you are in Canberra
ACT Brakes at Belconnen (Nettlefold St) - I think Steve was the man. About $60 to unstick one caliper and overhaul both rears. Plus I got a big tube of the proper PBR grease off them to stop it ever happening again.
AJ - its a common problem for single piston sliding calipers (all model MX5s, not just NBs). The brake guy told me BMWs and Pajeros were the worst, but with regular servicing (ie greasing) it should never be a problem.
I think the NCs have an identical design as would 99% of the cars out there so expect it to be an ongoing problem
Flawed design? Possibly. Cheap to make? Definitely.
- AJ
AJ wrote:*makes a note for the next service* check slider pins on rears for binding, grease as necessary.
obviously on a car that doesn't do big k's, i'd expect the problem would be exacerbated
Yep - that was my problem. You would usually do it each pad change, but when the first pad change happens after 6 years you will have a wee problem.
I reckon I will grease the pins from now on every 6 months. The last time I was at Wakefield I would have been braking with only three wheels
- Jimmy
thanks for the input lads. Ive just spent that time hitting, smacking, abusing, spraying wd-40 at everything, swearing, drinking and throwing stuff at the damn pin, then mum called me in for dinner, then i went out again and greased, drank, hit etc but its not budging
Thanks for the recommendations Casey, its going to ACT Brakes first thing in the morning. I took a look at the rear left as well and the pin is completely rusted. Guess its time for a caliper overhaul. But at least they can remove my broken speed bleeder
Makes me think that ive only been using the fronts for as far as i can remember...
Lesson for the Kids: Grease your rear (and front) caliper pins OFTEN.
- Jimmy
I've tried hitting it every possible direction. It's being a stubborn little bitch. I'll let the brake guys sort it out tomorrow. Because the pins are rusted, i'd much rather get them redone properly so that the pins are nice and smooth. On that note, what exactly do they do in an \"overhaul\"? Do they just bore out the pin hole and put in a new sleeve and replace the old pin for a new one?
