Possible to remove rear badges on an NB8C?
PASHN8
Postby PASHN8 » Tue Mar 11, 2008 2:38 pm
Hey guys,
Does anyone know if the 'MAZDA' and 'MX-5' rear badges on an NB8 series MX-5 bolted to the rear beaver panel with holes underneath them, or are they just stuck on using double sided adhesive tape?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
Juffa
Postby Juffa » Tue Mar 11, 2008 3:14 pm
I believe they are stuck on, no holes. If you remove the rear boot lining you should be able to confirm if there are any holes. There have been some threads on the USA forum on how to remove them....something like heating with a hair dryer to soften the glue and then cut with something thin, like fishing line.
J
PASHN8
Postby PASHN8 » Tue Mar 11, 2008 3:48 pm
Will check it out, thanks Juffa! :) Would like to de-badge the SE to clear up the rear end, far too busy with 3 badges on such a small rear panel!
- 2005 MX-5 SE
MasterZ
Vehicle: NA6 - Turbo
Postby MasterZ » Tue Mar 11, 2008 4:07 pm
Juffa wrote:I believe they are stuck on, no holes. If you remove the rear boot lining you should be able to confirm if there are any holes. There have been some threads on the USA forum on how to remove them....something like heating with a hair dryer to soften the glue and then cut with something thin, like fishing line.
J
Dunno about the NB8 series, but i'm currently getting my NA6 completely sprayed and my badges are removed right now and i got holes on the right. See....
1992 Mazda MX5 Turbo | 2004 VW Golf GTI | 2010.5 VW R36 Passat Wagon | 1985 Mazda HBES 929 13b Turbo | 1987 Mazda RX7 FC3S Turbo | KE20 Corolla Coupe
Alex
Postby Alex » Tue Mar 11, 2008 4:45 pm
yes there are holes as well, well at least in the NB8A there is
Boags
Postby Boags » Mon Apr 14, 2008 7:46 am
I'd want to get rid of the SE badge too... :mrgreen:
Alex
Postby Alex » Mon Apr 14, 2008 3:32 pm
:shock:
Users browsing this forum: Bing [Bot] and 6 guests
