1.8 diff into a 1.6 - more questions
JSE
Postby JSE » Tue Mar 04, 2008 6:36 pm
im doing a full conversion 1.8 motor, driveshaft and diff into my 1.6. just want to know if i buy brakes and suspension for the 1.6 will i still be able to keep them as bolts on mods with the 1.8 diff?
put simply will i need to change the suspension or brakes when i put on the 1.8 diff and driveshaft?
Fatty
Postby Fatty » Tue Mar 04, 2008 6:41 pm
they are all seperate parts, no dramas at all. i had 1.6 brakes with a 1.8 diff until recently. suspension is the same na6 or na8. no difference at all.
Fatty
Postby Fatty » Tue Mar 04, 2008 6:43 pm
oh the only thing you didn't mention is halfshafts - you need to change them as well when you put the 1.8 diff and driveshaft in.
corners
Vehicle: ND - Supercharged
Postby corners » Tue Mar 04, 2008 7:07 pm
Yeah they only thing you change for a 1.6 to 1.8 diff conversion is
- Tailshaft
- Diff & Diff housing
- CV shafts
Everything else stays the same.
JSE
Postby JSE » Tue Mar 04, 2008 9:17 pm
cheers guys, exactly what i needed to know!
JSE
Postby JSE » Wed Mar 05, 2008 8:12 am
just another question...when i pop in the 1.8 bp motor what parts will i need to change apart from the motor itself?
looking at buying brake cylinders, clutch master and slave, radiator, small parts like that etc.
what parts will i need to upgrade from my 1.6 to 1.8?
wun911
Postby wun911 » Wed Mar 05, 2008 10:35 am
Thats a lot of parts, why not buy an NB?
every ounce counts
