"Rosanna" (NA8)
- Steampunk
"Rosanna" (NA8)
Engine:
- MegaSquirt PNP MM9495, with Innovate Motorsports LC-1 Wideband Lambda sensor
- Apexi 4-1 extractors with spiral collector and flexi joint just before cat
- 2.25\", mandrel bends, from cat to stainless muffler
- Monza PCV filter
- MSD Ignition SuperConductor 8.5mm
- Stebel Compact Nautilus air horn
- MX5-Plus stainless steel radiator air re-direction plate.
- exhaust/high-temp wrap on headers.
- BEGi coolant re-route kit
- thicker core radiator from an automatic NA
- ACL heatshield
- Green Cotton Twister air filter
- Aero Turbine muffler
- Mazdaspeed IRTB
Drivetrain:
- Torsen type-1 LSD (4.1 ratio)
Suspension & wheels:
- Whiteline rear anti-sway bar, 16mm solid (adjustable)
- Koni Sport dampers &
- Eibach springs
- Beatrush rear strut tower brace
- Racing Beat front anti-sway bar, 24mm solid.
- Watanabe RS8 15x6 +14 Offset (with AVS centre-caps)
- Kumho Ecsta XS (KU36) 205/50 R15
- Carbing3-point strut-tower brace with BMC brace
Interior:
- Vent rings
- Skunk2 gear-knob
- Mazdaspeed pedals
- Mazdaspeed quick-shifter
- Mazda brushed aluminium gear-boot surround
- Mazda brushed aluminium hand-brake handle & button
- MX-5Plus Torque Box, twin-hoop rollbar
Exterior:
- Turn signal intakes
- colour-coded (sort of) bumper reflectors
- carbon fibre NACA headlight duct
- MX-5Plus offset license plate frame
- Custom Automotive Restyling Speed-Racer Decklid
- I.L. Motorsport grille (painted matte black)
- Mazda OEM front lip spoiler
Brakes:
- Hawk HPS pads F&R
- PBR drilled & slotted rotors
- Goodridge stainless steel braided brake lines
- Monza PCV filter
- ACL heatshield
- Mazdaspeed IRTB
Drivetrain:
- Eibach springs
Interior:
- Vent rings
- Skunk2 gear-knob
- Mazdaspeed pedals
Exterior:
Brakes:
- Hawk HPS pads F&R
- Steampunk
Dave, I was a little reluctant to put a photo of the engine bay cause, as you can see it's a dog's breakfast.
The intake is just a straight pipe with a lot of silicon bits surrounding it for heatshielding.
And how good are your eyes!! ....that pointy bit with the Mazdaspeed sticker on it, is just part of the carbon fibre heat-shield. I had a few Mazdaspeed stickers lying around that would end up getting thrown away or forgotten so I just stuck it on.
redshoes wrote:Looks great Andrew. Well, the outside does - I have no idea about the engine side of things. I think I need to find a place to learn...
Just get one of us to send you the mx-5 repair manual, start by popping the bonnet of you car and identifying all the different parts.
Once you know what is which you can focus one what they all do.
Soon you'll be CAI'ing so your AFM will work better with your CAS mods.
- Steampunk
- Steampunk
- Steampunk
"Rosanna" (NA8)
- StanTheMan
"Rosanna" (NA8)
just courious
have you had dyno run on this?
- Steampunk
"Rosanna" (NA8)
Not since I've installed the MegaSquirt mate.
I'm going to take some time off work soon to arrange dyno time at both the place I did it last time, and at Gary Stewart's.
- slug_dub
"Rosanna" (NA8)
Great looking car 1red5! I especially like the Watanabe's... mmmmm Watanabe's. and the decklid looks really nice, matches well with the twinhoop bar.
- Steampunk
"Rosanna" (NA8)
Awww thanks....
And to think that a little less than two years ago, she was dead-stock and back then I would have fainted at the thought of modifying her even the slightest bit.
I've owned Rosanna for nigh on 10 years now.
- Steampunk
Users browsing this forum: No registered users and 238 guests
