ap racing big brake kit
- 16bit
I have recently come into contact with someone who works for AP Racing in the UK. I have the opportunity to get a big brake kit at a discounted rate.
http://www.apracing.com/info/products.a ... _1669_1050
this is probably a more useful link for what is in it
http://www.apracing.com/info/index.asp? ... ke+Kits_30
My question is will this be worth the money - it will come in at less then the goodwin 4 wheel kit. I am thinking of getting a daily driver next year and make my car into more of a drive to track/moutain driver only.
- Hellmun
- Vehicle: NB8B - Turbo
Two things you want to consider in racing is the class you want to race in and how much your willing to pay for tyres. Big rims are needed to clear those calipers. Additionally most supersprint style classes stipulate you can only upgrade brakes to that an upgraded same model car. So you go into the real race-car league. Plus of course without the power to really need it...expect to just be using street pads. A big rotor/caliper setup makes it much harder to get heat into the brakes and keep it there.
My reference would be the hello kitty silvia at circuit club events. He upgraded an S13 silvia to use R32 front calipers. This is a 140kw ATW N/A CA18DET silvia and he was running 1:09's around wakefield...he couldn't use a race-pad anymore with the R32 front brakes. He went back to DS2500's.
- PASHN8
If I read correctly they require a minimum of 16\" rims to clear the caliper, and a 276mm x 34mm disc? That isn't really that extreme is it?
NB8B's onward come with a 16\" rim anyway, you might struggle with the factory offset though to clear the calipers?
I used to run R32 GT-R caliper/discs on my old SR20DET 180sx combined with AP Racing pads and fluid, that ran just over 170kw @ the rears and couldn't fade them, they were also perfect for street/twisty runs as well as the track.
16Bit - How much landed for the MX-5 4-piston front brake kit? I take it it is a bolt-on?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- rossint
- Alex
Okibi wrote:Pixola has AP 4 pots under his factory 15" wheels
If the price is right i'd consider getting these and upgrading my wheels at the same time.
Group buy??
if they fit under my stock NB8A rims and the price is right then I'll also be interested
- Steampunk
- 16bit
like I said the kit will come in at less then the willwood 4 wheel kit.
the reason I am not getting the willwood based kit is I have heard the callipers are shite and flex. This is from people who have used them - not a guy who reads the catalogues or internets.
I will have to get some 16's but thats not too much of a big deal. I will probably end up getting the work cr kai ones
Its a bolt on kit. I should hopefully have an answer on how much it will be soon.
- CT
So many questions. APs are good gear, but really, they are wasted on a road car. I am looking at upgrading to the 4pots they stick on the lotus exige for the race car this year, but because the wilwoods flex that much that my pads taper. Apart from that, the wilwoods have actually survived pretty well on the racer (running 550deg temps and hawk dtc60 pads) and would be fine on a road car - no problems. The best upgrade is the larger rotors and unless you are going to up the size from the NB270mm to something more substantial like a 295x26mm rotor, I wouldn't bother. The bigger rotor increases the effeciency in both heat and torque which is why you improve your brakes in the first place.
- 16bit
what about this kit then
http://tinyurl.com/3a6vne - edit Okibi fixed stupidly long url -
its got 313mm rotors - would i need 16's or 17's?
- CT
- corners
- Vehicle: ND - Supercharged
- rossint
- orx626
- Vehicle: NC - Rotary
Brakes are only as good as the friction between the tyre and the road!
In other words...don't forget about your tyre performance....no point having brakes that have the capacity to put you through the windscreen by just breathing on them, if all you wind up doing is locking them up everytime.
