HID fog lights
Steampunk
Postby Steampunk » Thu Jan 10, 2008 10:41 am
Uhmm ... are you installing a proper HID kit into your normal headlights? or installing a proper HID kit into your fog lights? or just replacing bulbs?
- If you are installing a proper HID kit into your fog lights then I would think that it is both illegal and does not make sense.
Fog lights are not there to aid visibility, they are there to warn other motorists and pedestrians of the presence of your car in heavy fog. Fog lights have a steep angle downwards because if you are driving in heavy fog, the last thing you want is bright lights reflecting off it. Technically in heavy fog, you are supposed to drive with headlights on \"park\" (or whatever it's called) function\"and only fog lights on.
Police can also book you for driving with fog lights on all the time. (at least that is bookable several years ago)
- If you are replacing your headlights with a proper HID kit... why?
- If you are just replacing bulbs, with \"HID\" xenon woop-de-doo blue crystal blah blah blah, these are NOT HID, they only produce light with a blueish hue or very white hue.
Steampunk
Postby Steampunk » Fri Jan 11, 2008 9:25 am
No worries mate. I just don't want you to get in trouble. I don't know anyone who has been booked, but that doesn't mean it doesn't happen.
Congrats on the new car by the way, and welcome to the forum.
Have you joined the local MX-5 club?
chatchat
Postby chatchat » Mon Feb 25, 2008 2:05 pm
if forget about the legal part, 3000k or 10000k or even 16000k is better to fit in the fog lights?
I personally prefer 10000k or above, or a lot of people saying 3000k is very nice.
Garry
Postby Garry » Mon Feb 25, 2008 3:46 pm
No aftermarket HID globe can legally be retrofiited to a car unless it is equiped with self levelling headlights and headlight washers. So feel to fit whatever colour bulbs you want to as they are all illegal.
corners
Vehicle: ND - Supercharged
Postby corners » Mon Feb 25, 2008 6:47 pm
I wouldn't bother fitting HID to foglights. If i were going to run the risk of the legalities i would only fit them as my main driving lights. Its not that foggy often.
Postby Mr Morlock » Mon Feb 25, 2008 11:53 pm
There is some very sound advice being provided and impressive knowledge about HID lighting. Your lights whether they be fog lights or headlamps have been specifically designed optically to perform. As soon as you start to interfere with focal lengths with different light sources your reflectors esp in the case of headlamps no longer control beam patterns and dazzle or simply do not put the light where it should be. The projector lamps are very precise and in my opinion do a surprisingly good job for such a small headlamp. For those people who do country work you can fit aftermarket driving lamps and they will work very well for long distance. One other thing is that HID lighting also is more expensive to replace apart from matters of legality. Anyway we all choose what we want.
Postby sliq » Wed Feb 27, 2008 1:06 pm
group buy on HID's anyone? :P
chatchat
Postby chatchat » Wed Feb 27, 2008 4:54 pm
how much roughly each? I am looking for a set of HID anyway.
Postby Mr Morlock » Wed Feb 27, 2008 7:52 pm
It may be of interest that Hella have a xenon micro DE lamp ( driving lamp) cat #1302. I do not know how well it performs though for size it would be very good. Mounting in place of fog lamps might be possible or on a light bar and the product is legal though I am not sure of differing state laws. If you checked Hella they would be able to give some advice ( situated in Mentone Vic) and they have a web site. I have no idea of the cost.
corners
Postby corners » Wed Feb 27, 2008 7:55 pm
Mr Morlock wrote:It may be of interest that Hella have a xenon micro DE lamp ( driving lamp) cat #1302. I do not know how well it performs though for size it would be very good. Mounting in place of fog lamps might be possible or on a light bar and the product is legal though I am not sure of differing state laws. If you checked Hella they would be able to give some advice ( situated in Mentone Vic) and they have a web site. I have no idea of the cost.
I dont believe they would be legal as they still dont self tilt.
Postby Mr Morlock » Thu Feb 28, 2008 9:13 am
jcs86 these lamps are aftermarket driving lamps and gas discharge are legal and comply with ADR. Headlamps ( low and high beam) are a very different story however and you and others have rightly pointed that out .
Postby bruce » Thu Feb 28, 2008 11:16 am
That's all I need. People putting in HID lights and blinding me everytime they're pointed at me.
IS IT REALLY NECESSARY ! May look nice and give a bit better visibility, but maybe you should wear your prescription glasses if you can't see what is in front of you.
corners
Postby corners » Thu Feb 28, 2008 4:12 pm
Mr Morlock wrote:jcs86 these lamps are aftermarket driving lamps and gas discharge are legal and comply with ADR. Headlamps ( low and high beam) are a very different story however and you and others have rightly pointed that out .
Ah no problem
