(Don't ask Casey...SP's never break down!)
Craig wrote:*PAGING GARRY*
Craig wrote:In a roundabout way I was...Garry replaced his on his SP, and chill out I sold my old car to this guys Brother
blackster wrote:I believe its a Hybrid Garret based on GT25/28 design, some one correct me if I am wrong?
Caedrus wrote:The vibration starts at about 2300 RPM, and stops vibrating at about 3200 RPM. I am assuming that there has been some damage to the turbo. There is a definite lack of blow off valve pressure, and the car is just feeling a little gutless (if you can say that about an SP).
silverback2002 wrote:Do you know if they install the oil restrictor in the oil feed line.
I was told not to put it in with my NA 94. I have a GT2560R
Flyin miata in the USA said they dont use them because the MX doesnt produce much oil pressure.
Should I remove the restrictor from the feed line?????
Russellb wrote: Replacement cost NEW is around the $1300mark with 12 moths Warranty.
Benny wrote:Russellb wrote: Replacement cost NEW is around the $1300mark with 12 moths Warranty.
And what are the 12 moths supposed to do?
