NSW Club Track Day @ Wakefield - 17 February 2008
irwin83r
Postby irwin83r » Fri Feb 22, 2008 6:22 pm
Charlie Brown wrote:
Li7hium wrote:
Charlie Brown wrote:This year, with the change to the roll bar rule,
What change?
Looking forward to seeing you at the Super Sprint meets Phil!
Matt
You can now run soft top production cars without a roll bar. :D
However if an aftermarket bar is fitted, ie Brown Davis, it must comply with the 50mm (2") clearance above the helmet rule. :roll:
Go figure :?: Surely any bar is better than none.
That means any stock/modified MX-5 can enter the Series and I'm in Class 2B :D
ha that'd be right now i have a BD installed ill be told im not aloud to run....
ill just bring some spanners and if they winge ill take it out there :)
marcusus
Postby marcusus » Fri Feb 22, 2008 7:05 pm
Bugger. Next track day is on the 28th of April, and I'm planning on being in Queensland that weekend for a mates' wedding...
Return to “MX5 Motor Sport”
