NSW sprint series regs
Mactype
Postby Mactype » Thu Feb 21, 2008 10:36 am
Just looking at the NSW sprint series regs.
What type of catch are people using for the secondary bonnet catch? Not all that keen on drilling through the bonnet but if it has to be done so be it.
I'm running 15x8's on our NA8 will that put me out of class 2b, or is there a NA with 15x7's from the factory I can quote if need be?
Li7hium
Postby Li7hium » Thu Feb 21, 2008 10:40 am
Hey there,
For the secondary device I am simply using chain with latches at either end and hooking into the holes on the underside of the bonnet and near the radiator mount.
Got me through 6 events worth of scrutineering without any problems.
Matt
NA8
Wakefield 1:14:78 28-6-09! Oran Park GP 1:27:73 30-03-08 Oran Park South 54:50 14-10-2007 Eastern Creek 2:02:44 6-8-07
BRZ
Pheasant Wood 1:05.4940
greenMachine
Postby greenMachine » Thu Feb 21, 2008 12:32 pm
Got an old leather belt?
Using one existing bolt near the catch and an existing hole in the bonnet, and using fairly large washers, cut belt into appropriate lengths and bolt to car :)
Not the most glam, but cheap and quite functional.
I have seen swaged light guage ss cable, and I have previously used nylon (or whatever) webbing...
Check the regs re wheels, you can go up two inches in diameter and one in width. If that's the case you could also look for a 14 x 7. I don't know of any NA8 models that ran 15x7 or 14x7, but good luck looking.
I hope you can make 2B, looks like quite a few MX5s this year so it should be good fun 8) Also 3B could be tough going for an MX5, especially if that quick Integra turns up again :(
Charlie Brown
Postby Charlie Brown » Thu Feb 21, 2008 12:33 pm
I thought that post 31 December 1973 vehicles fitted with the standard manufacturers two fastening system, ie initial cable operated lock and the secondary bonnet catch, complies with the CAMS Super Sprint rules.
Can someone say if this is correct or not?
Mactype
Postby Mactype » Thu Feb 21, 2008 1:12 pm
was looking for something other than the old belt through the hood option.
Did some research and the NA M-series in the US had a 15x7 wheel option so I'm only going up an inch in width on that so should be ok!.
fattima
Postby fattima » Thu Feb 21, 2008 1:36 pm
The Vic club sells these or you could make your own. Screws into radiator support panel, when not in use I have a cable tie looped that it can clip onto and not rattle around.
http://www.mx5vic.org.au/merchandise/tiedown.asp
Charlie Brown
Postby Charlie Brown » Thu Feb 21, 2008 2:06 pm
Mactype wrote:was looking for something other than the old belt through the hood option.
Sorry, the 15x8 rims will not allow you to run in the Type 2 category.
See Vehicle Regulations clause 1.4 “….must have been commercially available to the general public in Australia”
Mactype
Postby Mactype » Thu Feb 21, 2008 2:42 pm
oh well, into class SVB..... and I can do what I want - cool!
Hellmun
Postby Hellmun » Thu Feb 21, 2008 7:08 pm
Charlie Brown wrote:I thought that post 31 December 1973 vehicles fitted with the standard manufacturers two fastening system, ie initial cable operated lock and the secondary bonnet catch, complies with the CAMS Super Sprint rules.
When I was talking to Mike Hicks at wakefield on Sunday he said I'd need a fire extinguisher, blue 150mm battery triangle and secondary bonnet restraint. Surprisingly two tow hook stickers weren't required though (just had to actually have 2 tow hooks). I'll probaly still get some stickers made. There's a sticker place in Sutherland that makes CAMS stickers I found on google at work the other day.
Charlie Brown
Postby Charlie Brown » Tue Feb 26, 2008 6:33 pm
hellmun & irwin...can't seem to find your names on the SS list.
Are you going to enter this year :?:
Hellmun
Postby Hellmun » Fri Feb 29, 2008 8:19 pm
I was planning on it. Just today I got an invoice in the mail for $50 though I've no idea what it's really for. Doesnt' even mention if you pay by CC/Cheque/Money order etc. I know I put in Credit Card details on my registration form that I'd already sent....it has \"paid\" stamped on it in light blue in 2 places but it says amount paid is $0.00 on the bottom on the tear off. I might have to call someone tomorrow.
irwin83r
Postby irwin83r » Sun Mar 09, 2008 12:52 pm
im still yet to send my forms and alike off.
every arvo i seem to be getting stuck at work of late and dont make it to the post office :?
might be... \"sick\" on monday and sort it all out then :P i really dont want to miss out on this either...
Charlie Brown
Postby Charlie Brown » Mon Mar 10, 2008 10:16 am
I received (by e-mail) the NSWRRC entry form for Oran Park on 30 March over the weekend and sent it off to them today.
As I'm a newbie in State Supersprints, my number won't be allocated until Wednesday.
Where is the easiest place to get numbers from that's close to the city?
Li7hium
Postby Li7hium » Mon Mar 10, 2008 11:26 am
I don't know Phil, but if you find out, can we do a \"group buy\"? :mrgreen:
In all seriousness, if you find a place, let me know.
Matt
NA8
BRZ
irwin83r
Postby irwin83r » Mon Mar 10, 2008 11:41 pm
Li7hium wrote:I don't know Phil, but if you find out, can we do a "group buy"? :mrgreen:
Matt
ill be in on that
i think helmun too
Return to “MX5 Motor Sport”
