Short Shifters
- TieNN89
Short Shifters
Anyone here got a short shifter for an NB?
Where abouts did you get it and how much?
And what do you think of it?
And will it cause any damage? increase wear?
- TieNN89
MX5parts is selling one http://www.mx5parts.co.uk/product_info. ... cts_id/556
Please note: The 6 speed lever will only fit cars prior to Chassis Number: NB18**214807 (approximately August '01). The 5 speed lever fits all models to date.
but it'd cost somewhere around $150-$200AU landed
- pcmx5
- Vehicle: ND - 2
AZNTieN wrote:MX5parts is selling one http://www.mx5parts.co.uk/product_info. ... cts_id/556
I have a 10AE 6 speed in my car and bought a Simpson Design short shifter(about $180 landed).
Obviously there is a difference in later NB 6 speeds as Jim Simpson made it clear it was ONLY for an early 6speed.
It works well, makes the 6 speed feel much more precise.
6 speeders have two slots in the "ball" at the base of the lever,ie.two locating pins in the housing so a 5 speeder will fit a 6 speeder only if you make another slot.
Peter.
- Benny
- TieNN89
- Steampunk
- TieNN89
- PASHN8
Does anyone make a short shifter for a NB8C SE 6-speed?
- 2005 MX-5 SE
http://www.dinography.com.au - From the ground
http://www.skysight.com.au - From the air
- Steampunk
pcmx5 wrote:AZNTieN wrote:MX5parts is selling one http://www.mx5parts.co.uk/product_info. ... cts_id/556
Peter.
The ones Boags and I organised are only designed for NA's. Haven't found any economic ones for NB's. It's ridiculous how much shops want for them. I've seen $200+!!
I've even seen one shop (that had a write up in the US Miata.net forum) that sells that standard shifter, but cut short, for $100.
- PASHN8
Only problem is a shifter that is 'cut short' reduces the height of the actual gear knob, but doesn't necessarily reduce the 'throw' between the gears
- 2005 MX-5 SE
