Tyre choice
Juffa
Postby Juffa » Fri Feb 15, 2008 10:27 am
Have you seen this post?
http://www.aus-cartalk.com/viewtopic.php?t=24296
However I suspect that your particular issue (can you call this an issue?) may beyond a simple tyre change, I suspect you are going to need wider wheels (and larger diameter) wheels to give you the extra surface area.
What power are you putting out?
J
Blue94t
Postby Blue94t » Fri Feb 15, 2008 12:29 pm
I run 15x7 on my NA8 turbo with 205/50/15 RE55s tyres for the track.
With 160rwkw I light up the tyres in 2nd gear in a straight line under full throttle application. This is with a Torsen lsd.
With Dunlop FM902 205/55/15 on the street I was lighting up 3rd if the surface wasn't good.
The MX5 is designed to go around corners so you are always going to struggle with traction in 1st in a FI car. There is simply too much torque.
Winding down your boost or changing to a setup that allows higher boost in higher gears could be an option.
Jake
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Feb 15, 2008 12:33 pm
you should have got a supercharger :mrgreen:
Blue94t
Postby Blue94t » Fri Feb 15, 2008 12:38 pm
Why is that?
Because superchargers dont make enough power to spin the wheels? :mrgreen:
Jake
green_comet
Car Detailing Guru
Postby green_comet » Fri Feb 15, 2008 12:39 pm
You could always save up for the time being, and get a set of 15x8 6ul wheels from 949 racing, that were designed for MX5's with high horsepower.
http://949racing.com/index.asp?PageAction=VIEWCATS&Category=2
Then you will have no problem running a 225 tyre..
16bit
Postby 16bit » Fri Feb 15, 2008 1:07 pm
Blue94t wrote:Why is that?
Jake
no because its a much more linear delivery perfectly suited to the 5 - unlike that ghastly nothing then everything of turbos. its a Cretans sport.
green_comet
Car Detailing Guru
Postby green_comet » Fri Feb 15, 2008 4:33 pm
about the $1100 mark I think..
Craig
Postby Craig » Fri Feb 15, 2008 8:14 pm
A set of 15x7's, a Torsen LSD and a set of Toyo RA1's will fix that problem...maybe! :lol:
Postby manga_blue » Fri Feb 15, 2008 10:34 pm
205/50 would go better on a 15 x 7. Mine were just a little too rolly on the 6.5.
