NA bonnet slightly raised
silverback2002
Postby silverback2002 » Mon Feb 04, 2008 10:43 pm
Hi there,
I have tried adjusting my bonnet so it meets flush with the front bar but it is about 2 mm raised.
The lower striker attached to the frame on the car is adjusted as low as it can go.
The striker on the bonnet seems to be grooved out approx 2 mm. causing the bonnet to be constantly raised.
I have had a look to see If I can remove the bennet striker, it is riveted on but dont think it can be removed.
If anyone out there has a NA can you check to see if your striker on the bonnet is grooved out or is mine stuffed.
How would I fix it a weld job????
Anyone with info would help me out.
AJ
Postby AJ » Mon Feb 04, 2008 11:48 pm
i'd be inclined to think you bar was skewiff rather than the bonnet mate, especially if you've gone as low as you can go with adjustment :?
XMX5 Rogues
dingmaz
Postby dingmaz » Tue Feb 05, 2008 7:46 am
Have a look at page 7 in \"labour of love\" topic--the bonnet catch was filled. Mine is the same and I am looking for clues as well.
silverback2002
Postby silverback2002 » Thu Feb 07, 2008 7:56 am
Yes that is the latch i have the problem with.
It is worn out on the top side some how. I need to fill it with something.
Do you know what they used or did they just weld it and then file down smooth??
Users browsing this forum: No registered users and 122 guests
