car interior overheating...
metris
Vehicle: NA6 - Turbo
Postby metris » Fri Feb 01, 2008 1:50 pm
Hey everybody,
It seems the search functions is buggering up...
Can anyone point me to the topic that discussed the problem with the interior overheating? i vaguely recall reading something about sticking some insulation on the firewall...
Any ideas?
Cheers.
NA6 turbo cute scary fun machine!! :D
Fatty
Postby Fatty » Fri Feb 01, 2008 1:56 pm
on top of the firewall there is a rubber seal that is meant to seal the engine bay from the area behind it (which is where your interior air intake is).
this gets compressed over time and becomes less effective. phil (manga blue) was talking about this recently and he said he has ordered a new one. like you, i'm also waiting to see phils' results as i have the same problem . (air coming into cabin is very hot)
metris
Postby metris » Fri Feb 01, 2008 2:11 pm
cool cool thanks Fatty.
I read somewhere also about the insulation on the firewall... have you heard of that? I wonder how much difference it makes...
Fatty
Postby Fatty » Fri Feb 01, 2008 2:55 pm
hmmmm, from memory i think maybe it was garry who had been playing around with insulation on the firewall in his SP ??
marcusus
Postby marcusus » Fri Feb 01, 2008 7:12 pm
I can vouch for re stuffing the insulation strip in my NB8A. Made a world of difference.
It's not so much that over time the strip compresses. It's more that the strip Mazda put in is just hollow and transfers heat very easily.
I went to Clark Rubber and got them to cut me a strip of foam about 1cm in diamater and just stuffed it into the hollow strip.
The car still overheats, but only if I'm in traffic. As long as you're on the move, there's no problems with outside air coming through at the outside air temperature.
JSE
Postby JSE » Fri Feb 01, 2008 7:35 pm
softys...
Juffa
Postby Juffa » Fri Feb 01, 2008 8:57 pm
Another possibility is that the upper and/or lower gear stick boots have split which can let heat from the grearbox/engine into the cabin.
J
marcusus
Postby marcusus » Fri Feb 01, 2008 9:35 pm
Juffa wrote:Another possibility is that the upper and/or lower gear stick boots have split which can let heat from the grearbox/engine into the cabin.
J
Can you elaborate on this a bit? Do you mean the vinyl boots have a crack in them, or is it something I'm not getting?
green_comet
Car Detailing Guru
Postby green_comet » Sat Feb 02, 2008 9:57 am
Juffa is talking about the two rubber boots that are under the console. They develop cracks/tears over time, and let in heat from the gearbox oil.
Have a read from this page onwards..
http://www.miata.net/garage/trans/22.htm
As for insulation, I have been looking at installing some Fatmat into my car. It is similar to dynamat where it is a sound suppressor, and also an insulator for the car. So it keeps the heat out in summer, and the heat in during winter. It is also supposed to do wonders in illiminating road noise, etc.
http://www.fatmat.com
Mx5 install..
http://forum.miata.net/vb/showthread.php?t=243009&highlight=fatmat
marcusus
Postby marcusus » Sat Feb 02, 2008 4:52 pm
green_comet wrote:Juffa is talking about the two rubber boots that are under the console. They develop cracks/tears over time, and let in heat from the gearbox oil.
Ahh right. Might check those out at some stage as I can get a fair bit of heat coming through the gear shift.
Postby Okibi » Sun Feb 03, 2008 1:57 am
Always worth a check, ours has gone through 2 outer boots and one inner so far.
Garry
Postby Garry » Mon Feb 04, 2008 1:47 pm
I tried the insulation inside the rubber seal trick and didn't find it particulary effective. I lined the leading edge of the air plenum thing with some 10mm thick grey insulating foam and that seemed to work at lot better while the car is moving at least. The incoming air still heats up when stuck in traffic though.
Some bodgy pics here
http://www.cardomain.com/member_pages/show_image.pl?bg=FFFFFF&image=http://memimage.cardomain.net/member_images/1/web/205000-205999/205276_8_full.jpg
http://www.cardomain.com/member_pages/show_image.pl?bg=FFFFFF&image=http://memimage.cardomain.net/member_images/1/web/205000-205999/205276_9_full.jpg
AB7
Postby AB7 » Mon Feb 04, 2008 2:11 pm
Yep, I tried that foam thingy...even a rubber version of it that make the rear of my bonnet bulge a bit :shock:
Still hot...I just accept it
MX5: 1 Me: 0
Benny
Postby Benny » Fri Feb 08, 2008 3:45 pm
What do you think your air conditioning is for?
GP
Postby GP » Fri Feb 08, 2008 4:08 pm
Taking what little power the engine has and strangling it. :D
Graham
Users browsing this forum: No registered users and 146 guests
