coolant bubbling noise
In the last few days I could hear this coolant gargling sound coming behind the dash,probably the heater core,has anyone had this problem?I'm thinking leaky headgasket,but coolant level has not gone down,the car does feel a bit unresponsive down low compared to it's normal self,idle up to 3000rpms,what can I check to see if it is the headgasket?it is a turbo na6,runs fine apart from that,just want to fix it before it gets worse.
- Steampunk
white-ish residue in the coolant when you look into the radiator, same with looking at the engine oil cap.
Get someone to to stomp the accelerator, whilst it's parked & in neutral of course, and rev it to 6,000rpm or so, to see the colour of the exhaust smoke.
Once again, whitish smoke could mean head-gasket.
The noise could be your AC though.
- Craig
- Vehicle: Non MX-5
1red5 wrote:you sure it's not the ol' 'gearbox neutral switch' problem Craig?
* Removes gearstick and cracks 1red5 over the head with it *
*** Audi Q5 55 Sportback - HYBRID! Zero -100 in 5.3 seconds!
