teins which way to lower
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue Jan 29, 2008 4:57 pm
just wondering which way I screw the teins to lower them - seems stupid i know :roll:
Matty
Postby Matty » Tue Jan 29, 2008 6:01 pm
down.
16bit
Postby 16bit » Tue Jan 29, 2008 9:29 pm
thanks - i figured it out after i posted. and i made use of the info
CapitalF
Vehicle: NA6 - Turbo
Postby CapitalF » Thu Jan 31, 2008 10:57 pm
Note that if you lowered the car a lot you may well need a wheel alignment to prevent significant tyre wear and ensure handling is not negatively effected.
I dropped my NA 30mm in the rear and slightly different (much smaller) amounts in the front to level the front up (L/R) and needed a wheel alignment big time.
Peter
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
marcusus
Postby marcusus » Thu Jan 31, 2008 11:19 pm
Hmmm... should probably go get that done considering I dropped the car from stock to lower than stock Tein SS... :?
JBT
Postby JBT » Fri Feb 01, 2008 12:00 am
You will most definitely need a wheel alignment if you stuff around with the suspension in any way - particularly lowering.
16bit
Postby 16bit » Fri Feb 01, 2008 9:05 am
ic well i have not dríven the car yet so it might be to fulcrum for a wheel alignment. that said it is technically illegal so it may not be worth me leaving at that level. I think it dropped about 15mm.
Users browsing this forum: No registered users and 173 guests
