basic audio upgrade
sweep77
basic audio upgrade
Postby sweep77 » Sun Jan 27, 2008 9:45 am
just thought i'd show a couple pics of what i did yesterday. Just got some cheap tweeters and crossovers and mounted them. everything is standard except the headunit. Actually sounds ok! lacking a bit in bass but the mids and highs are quite good considering the cost i paid lol
marcusus
Postby marcusus » Sun Jan 27, 2008 4:50 pm
Are they mounted on the door trim? Don't suppose you're having any problems with kicking them when getting in/out of the car?
TieNN89
Postby TieNN89 » Sun Jan 27, 2008 9:14 pm
when your driving don't they get in the way?
sweep77
Postby sweep77 » Mon Jan 28, 2008 4:15 pm
i made up a bracket so they are mounted on the door slider hinge thing. no issues with hitting when driving cause your feet are in front of them. u have to be a bit more careful getting in but most of the time its fine
AJ
Postby AJ » Sun Feb 03, 2008 7:37 pm
:? that's a great start to your posting career :roll:
XMX5 Rogues
sweep77
Postby sweep77 » Sun Feb 03, 2008 8:24 pm
its not supposed to be some expensive well setup audio system. was just a cheap idea to see what it was like. was cheap and sounds good so no sweat off my back.
wun911
Postby wun911 » Fri Feb 08, 2008 2:19 pm
I dont see anything wrong with that setup, I have seen this been done before but not in an MX5...
http://www.crutchfield.com/App/Product/ ... 221&tp=404
Apparently they sound better because it \"directional\" ie pointing the speakers towards the driver...
every ounce counts
sweep77
Postby sweep77 » Fri Feb 08, 2008 5:19 pm
exactly. if you know anything about car audio then a great deal of winning systems have the tweeters mounted down low pointing to the roof of the car. it brings the soundstage up to around windscreen level and minimises sounds delay. sure its not a professional install but it works until i get some decent speakers.
muzzy66
Postby muzzy66 » Wed Mar 19, 2008 8:28 pm
The tweeters themselves actually probably don't sound too bad - as long as they aren't producing ALL of your sound frequencies, it should be a significant upgrade over original. :)
Users browsing this forum: Google [Bot] and 9 guests
