Test and Tune this saturday BRISBANE
Queensland Events
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Thu Jan 17, 2008 4:16 pm
I am going out to Willowbank this saturday for a test and tune - anyone is welcome to come along. I will be running my car for the first time and I have never been so don't laugh!
I know quater mile racing is not really mx5ish but thought i would offer.
Steampunk
Postby Steampunk » Thu Jan 17, 2008 4:36 pm
Heck I took the Festiva down the strip so why not take yours? :wink:
Is there gonna be a drag event coming up in the next week? if so then it will packed.
Shoot me a PM with your mobile and I'll see if I can make it.
A friend of mine was gonna go soon, so maybe he's also going this weekend.
16bit
Postby 16bit » Mon Jan 21, 2008 10:29 am
went out - it was not too bad at all. I ran a 14.7 at 96mph. The mph suggests a 14 even time should have been done. I did not reduce the tyre pressure or soften the rear end for it as I wanted an every day driving setup time. Also the lack of an lsd and me not doing a burnout probably lost time too. Overall I am happy with the mph by my 60 foot times are pretty sh*t - 2.3 was my best. I did get faster times then a turbo silvia and an r33 gtst.
Steampunk
Postby Steampunk » Mon Jan 21, 2008 10:38 am
Good stuff. Sorry I couldn't make it.
Did anyone take video recoding of your run?
AB7
Postby AB7 » Mon Jan 21, 2008 10:57 am
I wondering, what is the the QT mile time of standard NB, SE and SP?
nfs13b
Vehicle: 10AE - Turbo
Postby nfs13b » Mon Jan 21, 2008 2:30 pm
Thats some pretty good times, with a bit more practice you will improve the times. Did the car wheelspin at all?
MX5 13B - NFS Racing
PRO-MX5 PB 7.46 @ 179mph & 1.07 60ft
16bit
Postby 16bit » Mon Jan 21, 2008 3:12 pm
farkin sh*t loads!!! the first run it span up through pretty much all of first gear at did a 14.89 - then the second it span until 4500rpm which was the 14.7 and the third it span badly and I had to peddle twice and did a 15.5
nfs13b
Postby nfs13b » Mon Jan 21, 2008 3:15 pm
yeah drop the tyre pressures. Usually if you wheelspin it increases the mph.
16bit
Postby 16bit » Mon Jan 21, 2008 3:41 pm
yeah i found that - got 1mph more on the first run. kind of odd but seems logical
Marador
Postby Marador » Tue Jan 22, 2008 10:49 am
AB7 wrote:I wondering, what is the the QT mile time of standard NB, SE and SP?
I think i ran 14.5 with a slipping clutch in the mx5...
Silver SP
16bit
Postby 16bit » Tue Jan 22, 2008 9:37 pm
thats pretty good. I hope to get into low 14's tomorrow.
16bit
Postby 16bit » Wed Jan 23, 2008 7:58 pm
well i never made it to the strip today. my intention was to get a smaller pulley put on this morning then take it to get tuned then take it to the strip to test it. We got it on the dyno and about half an hour in or so it was discovered that the 5th injector was not big enough. An attempt to order a bigger one failed with the wrong part turning up at around 4:30. So I have had to take the car back and only rev it to 5000rpm until the car goes back in a week and half. I am not going to speculate on power output yet but we will see on the 9th.
16bit
Postby 16bit » Mon Feb 11, 2008 9:39 am
It made 150 atw but the belt was slipping so it missed out on about 2-3psi in the top. I would think about 160-165 will be had once i get the problem sorted. I was attempting to change the belt and sheared the bolt off the tensioner so its only got a really tight belt and no tensioner at the moment. Will have it sorted on wednesday and then probably do a power run and check the afr on the weekend. Its on 12.5 afr so its nice and safe.
Return to “Queensland”
