MY CAR BROKE DOWN FOR THE SECOND TIME..... (update page 4)
Postby Okibi » Fri Jan 04, 2008 1:06 pm
Andrew wrote:They have just been able to pull a fault code from the car and the CAS is failing.
I wonder why they didn't pull this code before .. or do they just plug their ODBII computer into Aus-cartalk?
Andrew
Postby Andrew » Fri Jan 04, 2008 2:38 pm
No idea.
The had the car running in the workshop for a three hour period and couldnt fault it until yesterday when the code appeared.
Will see what happens on the way home tonight :D
davamb
Postby davamb » Fri Jan 04, 2008 2:59 pm
Just my 2c for what it's worth - I'm not familiar with the CAS on the MX, but on other cars I've known, an error is logged for the CAS if the engine is not running when the computer is interrogated, leading to a lot of replaced CASs for no reason. Can anyone advise on whether this is true for the 5?
Cheers, Dave, 1990 NA6
Via est vita.
Caffeine
Postby Caffeine » Sat Jan 05, 2008 8:11 am
Andrew wrote:Image
ewww! what fuel do you use? My coarse filter (the sock thing) is still calico coloured after 180000km, yours looks like you run the car on chocolate!
Andrew
Postby Andrew » Sat Jan 05, 2008 10:45 pm
So far the cars is going good :)
Caffeine wrote:ewww! what fuel do you use? My coarse filter (the sock thing) is still calico coloured after 180000km, yours looks like you run the car on chocolate!
I currently use Shell V-power as it has a red pump handle :P
Agro
Postby Agro » Sat Jan 05, 2008 10:55 pm
Hey all....thanks all for your assistance. Andrew has been keeping you all in the loop about the happenings while I have been at work. Work have hopefully fixed the issue now, I have been driving around the last 2 days and nothing has happened...the car is great and with no issues. So hope it stays that way for a while. It is due for it's 130,000km service though!
How would I know, I'm only a puppet!
Caffeine
Postby Caffeine » Sun Jan 06, 2008 9:07 am
Andrew wrote:So far the cars is going good :)
Here's a new one :
Mine looked similar to that after 150000km on optimax, VPower (non ethanol), Ultimate 98 and mobil synergy 8000
I prefer to fill up with bp ultimate because the handle is blue (like optimax was) :D
StanTheMan
Postby StanTheMan » Sun Jan 06, 2008 9:31 am
spare one i've got looks like Andrews. I dare say the one fitted in my tank is the same chocolate colour.
My guess would be that its the normal petrol or the standard unleaded does this. My car drinks everything.
JBT
Postby JBT » Sun Jan 06, 2008 9:47 am
So.........what was the fix for Agro's car?
Andrew
Postby Andrew » Sun Jan 06, 2008 10:15 am
JBT wrote:So.........what was the fix for Agro's car?
They replaced the CAS and it is now working fine 8)
JBT
Postby JBT » Sun Jan 06, 2008 11:41 am
Andrew wrote:They replaced the CAS...
Aaaahah. Is this the VVT CAS on top of the cam cover?
Andrew
Postby Andrew » Sun Jan 06, 2008 11:46 am
Yes, toward the rear of the motor on the left hand side :D
Andrew
Postby Andrew » Sun Jan 06, 2008 12:01 pm
Here's a new one :
My old and a new pumps -
Havnt taken it out to check the colour of the filter though....
Postby sliq » Sun Jan 06, 2008 1:46 pm
Agro wrote:Hey all....thanks all for your assistance. Andrew has been keeping you all in the loop about the happenings while I have been at work. Work have hopefully fixed the issue now, I have been driving around the last 2 days and nothing has happened...the car is great and with no issues. So hope it stays that way for a while. It is due for it's 130,000km service though!
hi guys,
pretty much off topic, but can someone tell me what's in a 90,000km service? just oil and fuel filter replacement + engine oil replacement? thanks
Andrew
Postby Andrew » Sun Jan 06, 2008 1:51 pm
sliq wrote:hi guys,
isnt it listed in the owners manual :?:
