I bought a muffler and im wondering on how to fit it on my NA MX
heres the details on what i bought:
How does it work?
Varex muffler combines both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary between the two. For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car noteâ€) and near-zero resistance. Whilst for lower sound level, the exhaust flows are directed through the chambered path (similar design with the stock muffler), and produces minimum sound level that gives you the best in-car comfort. Also, you are able to control the angle of the valve which can be adjusted to stop at any point between the sports mode and the silence mode. This gives you further freedom to set the optimal sound level according to your preference.
XForce VAREX
Cannon VAREX:
Inlet size: 2.5
Barrel size: 7†O.D, 14†Long
Tip size:4.5†O.D single wall tip
Closed
Open
Remote for muffler
Sorry about a lot of writing
Here are my questions
Has anyone got a cannon style muffler on their mx5?
Will the muffler work, as in fit?
Do I have to get the muffler place to place it on an angle?
Would I have to cut a bit of the rear bumper to make it fit?
