Clubman badge (prototype page 8)
- green_comet
- Car Detailing Guru
- Alfadog
Looks great now!
Being a nit-picker......
- Top left of flag isn't quite round enough
- Angle of the underline at the left is a bit too steep
- The bottom right of the white space in the middle of the \"C\" has a kink, but should be smoothed out a bit.
I dunno how it will be produced but the flag might not come out as planned...
Please don't take my comments the wrong way. You've done a stunning job
Just trying to help out.
- Brad
- Andrew
- Tezzax5
- Andrew
Fatty wrote:actually, speaking of the sticker in the door - andrew is there any chance you can get these made up as well ? ? i guess you'll just need to get a picture of it from someone?
I'd need to see one (assume it would be the same as mine just with different info), the design would be easy and the printing shouldn't be all that hard or expensive.
Will finish this one first.
- Fuzzlet
any volunteers???
i already have the torsen fitted, and a set of bilsteins in the shed, so.....
Get caught with that and you'll be issued with a "put it on a tow truck and get it fixed within 7 days" defect notice...usually also comes with a fine around the $300 - $500 mark depending on state...
Plus there is also the fact that it degrades the original clubman, and will pull the value down for those wanting to sell an original
- Andrew
Fuzzlet wrote:Fatty wrote:actually, speaking of the sticker in the door - andrew is there any chance you can get these made up as well ? ? i guess you'll just need to get a picture of it from someone?
any volunteers???
....so just go and purchase an original from Mazda
