NA6 Rear Brace
NA6 Rear Brace
As mentioned in another thread, thought I'd put it here where it belongs so I don't offend anybody.
Designed my own version of the RB rear brace and had it made by the sheetmetal guy that does all our manufacturing at work.
It looks like this fitted:
I did want it in Zinc seal rather than hot gal so I could paint it black, but that was the only #14 gauge he had kicking around the shop on the day. The fit was just about perfect, I had to adjust 2 holes with a file, but this information can be fed back and the programming file adjusted for the next one. And now that the programming is done and paid for, I can get more run off for pretty low cost. It's all punch-and-nibble rather than laser-cut, but it ends up being cheaper per-unit if lacking in pizazz.
Finally got out for a drive last night. Noticeably tighter rear end. Nice.
Cheers, Dave, 1990 NA6
Via est vita.
Via est vita.
- Steampunk
No 1Red5, it's not made out of Zinc, it's #14 gauge mild steel, it's just zinc coated. The steel you can see on mine is galvanised, but Zinc seal is a much better coating with a good 'tooth' for paint to grip to.
I will find out the cost to run a couple more off and will have a look at what's required for the NA8, but I thought they already had the mod that joins the two sides of the suspension together??
Via est vita.
Via est vita.
- Steampunk
Juffa wrote:The RB brace has a small removable piece to allow you to fit the brace without touching the exhaust. Do have to separate the exhaust to fit this one?
Hi Juffa, no, no removable piece I'm afraid, had to disconnect the 'zorst at the back of the cat (and finding a broken stud along the way - see thread in engines and transmission section). Only took about 30 minutes to fit though, but this was with the rear of the car up on ramps.
Here's a link to my 'inspiration' but no joiner piece shown.
http://www.racingbeat.com/resultset.asp ... mber=54009
I'll have a chat with my sheetmetal guy on pricing. I'd want them black powdercoated for around $75 for 5-off, a bit better if I can find 10 customers. Anyone interested? (I'll put this up on the For Sale section too.)
Via est vita.
Via est vita.
Ah, on second thoughts I think mine might not be a RB one, but possibly Brainstorm. I bought it second hand from a fellow forum member (Sab).
On mine the small horizontal piece that sits under the exhause is removable, so you can fit and remove the brace without touching the exhaust. I have a 2.5 inch exhaust which does not clash with the brace. I'm pretty sure mine is aluminium. I painted it black, not big on the bling factor.
For those thinking about it, these do make a big difference. I actually cut off the factory brace to install it.
J
J
- rain902
- Matty
Juffa wrote:Ah, on second thoughts I think mine might not be a RB one, but possibly Brainstorm. I bought it second hand from a fellow forum member (Sab).
The one Sab had was a pattern of the Cannon brace off Nessy...
- rain902
rain902 wrote:Plan B - also saves weight
it saves weight by virtue of the fact that there is over a metre of zorst pipe & a dirty great muffler missing...
2013 Australian hillclimb champion 2F
2013 qld hillclimb champion 2F
Qld & Aus 2F state record holder-mt cotton
2014 vic hillclimb champion - 2A
- lowmiata
Re: NA6 Rear Brace
davamb wrote: And now that the programming is done and paid for, I can get more run off for pretty low cost. It's all punch-and-nibble rather than laser-cut, but it ends up being cheaper per-unit if lacking in pizazz.
Dont rule out laser cutting I get alot of stuff laser cut and Its cheaper for me to out source laser cutting than use the in house strippit punch!+ you get a nicer finish that needs less labour to complete.
its also much cheaper less labour (depending ou how you program it)
what sort of program was written for it?
EVI15 1998 to 2008
Users browsing this forum: No registered users and 25 guests
