I would like some informed opinions about this.
I know stock sizes, and I know what most manufacturers like Racing Beat and Flyin' Miata makes, but is there such thing as \"too big\" or \"too stiff\"?
There is a set I know of, the front bar is hollow (I think) and is a whopping 32cm in diameter.
The rear bar is also quite hefty, a solid 16mm.
Would this cause adverse effects for a car with stock suspension? What about a car that has decent dampers/springs/coilovers and upgraded end-links?
How big is \"too big\" for anti-sway bars
- Steampunk
- Boags
And you can say hello to lifting the inside wheel off the ground.
- Mr_Q
Re: How big is \"too big\" for anti-sway bars
1red5 wrote:the front bar is hollow (I think) and is a whopping 32cm in diameter
That'll stop any body roll.
Mister Q
Had: Red 2004 SE, Red 1993 NA8 Clubman, Green 1991 NA6 LE
- Woo
- Vehicle: 10AE - Turbo
Not quite, but just about. Imho it's a really good combo, makes it very cart-like
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
- Hellmun
- Vehicle: NB8B - Turbo
The hollow bar is not as rigid. There's a rough formula on whitelines site. I believe the 32mm hollow racing beat bar is equivalent stiffness to a 24mm solid bar.
I have a 16mm rear bar arriving any day now and I've already got a 24mm front in the car. Not a track day though until feb to test.... The rear is the biggest change. The NB8B atleast already had a 22mm front sway. The 16mm is a big step up from a standard 11mm rear. I believe SE's got 14mm rears standard though. It seems large but I'm hoping with pre-load adjustment and adjustable shocks I can hit neutral with it. I was rather torn between 14 and 16mm rear bars. Decided Whiteline only offering 16mm's with their 24mm solids hopefully had a lot of research behind it.....
As mentioned, 32mm hollow bar isn't all that stiff due to being hollow, but it weighs a lot lighter than a solid bar of the same stiffness.
I had a 16mm rear bar and 24mm front bar, with Koni and Kings. Kings were rated at 165-215lb/inch front and 105-160lb/inch rear, which were relatively soft compared to my Tein SS now (6kg/5kg or 336lb/280lb). This setup gave a neutral to slight oversteer setup depending on how you've set the rear bar. I had mine on the middle setting front and rear and I quite liked now it went. On track you can soften up the rear to give it more mid corner stability.
I now have Tein SS with the same 24mm front bar but I've now gone back to the 12mm stock rear bar cos I worried that the stiff 5kg rear springs and 16mm rear bar will cause massive oversteer. With this setup, it feels more stable with high speed corners with only a tad of understeer at tight hairpins.
The key to choosing swaybars is the balance between front and rear stiffness. With my limited experience, having a big front sway isn't a problem as long as there is a bigger rear sway to much. However, having too big of a rear sway will require a huge front sway. For my current setup, if I was to keep my 16mm rear sway, I would need a front sway of at least 27mm (solid too) to keep the same general feel as I have now. That's something which I'm not repaired or want to do at all. Plus stiff spings and big sways mean lack of suspension independence, which is also a problem
using the calculation method in the fatcatmotorsports spreadsheet, the racing beat hollow bar (1.125\" outer (29mm), 0.125\" thickness) is about 1.25 times the stiffness of a 24mm solid bar.
their larger hollow bar (1.25\" outer (32mm), 0.1875\" thick) is 2.3 times the stiffness of a 24mm solid bar - but not recommended for NA models.
according to the racing beat website, the 1.125\" hollow bar weighs 5.5lb (2.5kg) whereas their 0.93\" (24mm) solid bar weighs 10lb (4.5kg). So 2kg lighter.
so how much is a us$150 bar in Australia?
Steve
Steve
1993 NA1.8 (tein flex/cage/stripped/std engine/std brakes) lakeside 1'09" + trying
- Steampunk
- Garry
For street driving in an NB8B with stock springs and Koni's I have a 24mm front solid bar and I had a 16mm adjustable rear Whiteline bar. I found that setup a little bit tailly even on the softest setting on the rear bar. I switched back to the stock bar and had plough understeer in the wet, so got a 14mm rear bar made up. That combination and my alignment setup suits me perfectly.
If you go to a really thick front bar you will need to stiffen up the mounting brackets on the chassis rails. Apparently they have a tendency to crack if you use a bar over about 25mm thick (solid). There are a couple of manufacturers that make the upgraded brackets.
But to answer your question, yes it is possible to have to much roll stiffness.
- Steampunk
The 32mm and 16mm anti-swat bar set was actually for an NB, so for that, and other reasons, I didn't get it.
But it did weigh less than a 22mm solid stock NB front bar.
Garry is spot on with beefing up the standard bracing, but the kit sold by Racing Beat looks to be easily copi .... errr .... custom fabricated.
Users browsing this forum: No registered users and 372 guests
