Best 14\" tyre for occassional track work
Steampunk
Postby Steampunk » Thu Nov 29, 2007 9:51 am
I have 14\" wheels and have no idea of the offset nor the width.
Can someone point me in the right direction.
I currently have Bridgestone GIII and very happy with them. I guess what I am after is something very sticky, with a lower profile and/or wider footprint than 185/55.
Also, what pressures should I run for 5 lap sprints?
StanTheMan
Postby StanTheMan » Thu Nov 29, 2007 10:02 am
how many K's P/A do you expet to do in your car?
do you intend to use these tyres on the road or are you thinking of getting a seperate set of wheels.
best choice of tyres for racing is undoubtely in the 15\" catergory & will also give you a sghorter sidewall
Steampunk
Postby Steampunk » Thu Nov 29, 2007 10:14 am
I realise if I go 15's then the world's my oyster, but I'm working on a budget and also super-limited storage space, so I just want to have the same wheels&tyres for road and track.
As with km's p.a. = 4,000km max so tyre wear over time is not an issue as soft-tyres will last me quite a while.
StanTheMan
Postby StanTheMan » Thu Nov 29, 2007 10:26 am
start thinking about tyres like the Falken RT615, toyo R888. there is a few others......but don't bother going to full semislick tyres like DO1's and the like
R888 are R compound warm up pretty quick but ar not as soft as the DO'1
RT615's are a road compound with a semislick tread pattern warm up real quick on the track and ar not affected so much by heat cycles like DO'1
although RT615's do need w arming up around the street in winter but in Brissie I doubt you'll ever have any issues
Steampunk
Postby Steampunk » Thu Nov 29, 2007 10:31 am
[thumbs up] thanks Stan. :)
I've used various Falken's on another car and have been very happy with it's value.
RaYmO
Postby RaYmO » Thu Nov 29, 2007 4:33 pm
I'm getting Toyo R888s in the 14\" size next time (in the next 6 months or so)...
I don't go on track days so it should last me a good 20k km
Steampunk
Postby Steampunk » Thu Nov 29, 2007 4:44 pm
OK, so tyre brands has been answered.
What about pressures for 5 lap sprints?
StanTheMan
Postby StanTheMan » Thu Nov 29, 2007 5:03 pm
1red5 wrote:OK, so tyre brands has been answered.
I've only spoken about a few....there is many more. They are the 2 I know a little bit about. And have had first hand experience with. Wait for a few more suggestions.
However pressure will depend on weather conditions, hot day, cold day, wet weather, slippery track, grippy track & which tyre you end up choosing.
Postby orx626 » Thu Nov 29, 2007 6:52 pm
RaYmO wrote:I'm getting Toyo R888s in the 14" size next time (in the next 6 months or so)...
Hi Raymo, I run Toyo R888 in 185/60 R14 for track days on a stock NA8.....they have only lasted 5 days which equates to approximately 1000km (including travelling to and from the track). So I think you'll be hard stretched to get much more than 10,000km.
RaYmO
Postby RaYmO » Thu Nov 29, 2007 7:35 pm
:shock: Really?
Hmmm scrap that idea for the R888s then...
Postby orx626 » Thu Nov 29, 2007 8:16 pm
:shock: Really?
Yep...the R888's are plenty sticky though :twisted: .
Hellmun
Postby Hellmun » Thu Nov 29, 2007 10:36 pm
The R888's are real semi-slicks.... they heat cycle, they're very loud and the sidewalls make it sound like your in a constant industrial zone(Some say it's a whirring sound). If you have a headache or are plain tired and trying to get home...they suck. I havn't heard the toyo's personally but I'm told my RE55's were similar.
I believe the RT615 is a tyre designed to last a while and still give a decent amount of stick. Not considered very sporting if you used those in the standard class but for modified they'd probaly suit. Fastest standard road car in the club at the moment is running Dunlop Direzza DZ101's IIRC.
Tyre pressure is more...variable(compound, track temp, wheel temp etc). I found easiest way to do it was just use a infrared temperature gauge. I just reduce the pressures until the Outside edgeof the tyre and the centre are the same temperature directly after a lap session. Should mean you have the biggest contact patch. Camber will control the difference between the inside and outside edge.
For Reference my RE55S's have been to 3 track days..and I'd put my front left at about %30-%40 max left....Those were $304 and the Toyo's are about $274 at Blairs.
Steampunk
Postby Steampunk » Fri Nov 30, 2007 9:50 pm
Thanks for the responses fellas. Unfortunately I now know that semi-slicks are waaay out of my price range.
Phatmx, I was running 32 psi at QR and it started to feel like it was \"folding\" under on the last flying lap. Mind you, my alignment settings are not the best (needed more negative camber).
SteveS1 brought a laser tyre temp gauge and three corners were 45degrees, and left-front was 52degrees :) makes sense as QR is mostly right-handers.
Hellmun
Postby Hellmun » Sat Dec 01, 2007 11:08 am
At wakefield last trackday I hit about 68C on the front left, 56 on the front right, 58C on the rear left and 44C on the rear right. Those temps don't really matter so much.
It's the temperature difference between the inner and outer section of the tyre. That tells you if you have the pressure right. The car will tell you the right pressure per tyre and that's usually dictated by the temperature they're hitting. On the Bridgey's I start off at 32psi and just adjust them after every session. Wakefield being only Right hand turns is destroying my front left massively though... which really sucks because they're an assymmetric pattern.
Steampunk
Postby Steampunk » Sat Dec 01, 2007 8:27 pm
but if they were asymmetrical then you can get away with swapping them for any other corner, do you mean they are symmetrical, and thus can only be swapped for the other corner on the same side?
