Interior finishers
sabretooth
Interior finishers
Postby sabretooth » Thu Nov 29, 2007 2:05 am
As some of you know, I've successfully put an NB interior into my NA. As part of the NB dash you get the airbag cover. Of course, mine is blown. I've stuck the 'flap' bit back down in place, but obviously it doesn't look the best:
Does anyone know of a place that's handy with vinyl and would be able to re-cover it with the appropriate stuff, and make it look factory? I've been given the name of one place that could do the job, but would like a few others so that I can compare quotes. Cheers.
lowmiata
Postby lowmiata » Thu Nov 29, 2007 2:44 pm
Whats behind it sabre?
if there is enough room you can glue some flexy 12mm plywood (curved to shape) to the back of the panel and recover it yourself with black vynil
Shouldn't be that hard to get a similar matching vynil
better yet you could make it a hinged panel and use it as storage place for sunnies etc
only reason for putting the wood behind si so that when you re upulster you can staple the vinyl on rather than just glue it to the plastic as glues don't survive well in the direct sunlight and heat cycles.
Ryno.
EVI15 1998 to 2008
RaYmO
Postby RaYmO » Thu Nov 29, 2007 4:31 pm
lowmiata wrote:Whats behind it sabre?
Ryno.
That is an awesome idea!
NMX516
Postby NMX516 » Thu Nov 29, 2007 7:08 pm
All Car Interiors at umm, it's either Lutwyche or Windsor. Highly recommended :)[/list]
irwin83r
Postby irwin83r » Thu Nov 29, 2007 7:50 pm
sunnies holder would be sweet.
some of the hiluxs have a storage place there factory.
ive also seen a car with a three gauge cluster there mounted on an angle looking towards the driver... look very cool.
Boags
Postby Boags » Fri Nov 30, 2007 4:09 pm
There is a motor trimmers next to Rob Bliss Exhausts in Virginia... I've had heaps of stuff done there for my IMP and it's great quality.
Heritage Motor Trimmers (I think). :D
sabretooth
Postby sabretooth » Wed Dec 05, 2007 12:51 am
Ryno.
Behind it - empty! I've had a few suggestions to make it into a compartment, and it's something I've considered myself. Problem is that I don't know where to start with that, and how to actually make it look decent.
Thanks for the suggestions :D
Users browsing this forum: No registered users and 17 guests
