Speedo problem
Stu
Speedo problem
Postby Stu » Sat Jun 23, 2007 1:15 pm
My speedo seems to jump around sometimes whilst I am doing around 60km/h.
To clarify, If I am doing a constant 60 km/h my speedo will go up to 70, flick back to 50, up to 70 then maybe 0 then back to 60 all in the space of a couple of seconds. It only seems to occur in the first few km's of driving.
Is this a common prob? Do I need to adjust something, get mechanic to do it, or is it the start of a more serious problem?
Stu
Postby Stu » Sat Jun 23, 2007 1:16 pm
Forgot, I have an 01/02 NB8B
meanmx
Postby meanmx » Sat Jun 23, 2007 4:58 pm
That's just the way you drive mate :lol: . Sorry not much help. The only thing I can think of is that the connection into the gearbox or back of the dash cluster may be loose.
Ben
2014 VW Mk7 Golf R
sprx3
Postby sprx3 » Sat Jun 23, 2007 5:49 pm
hey stu, im not sure if they are electronic or mechanical, but if it is a cable drive (mech) you may find that the inner cable is dirty or on its way out... if someone can tell me what type they are im sure we could find a fix for it ;)
or like ben said it could be the way you drive
want to join the mazda car club of australia?, for more info please p.m me
Stu
Postby Stu » Sat Jun 23, 2007 6:46 pm
Car is serviced in 700kms, may just get mechanics to figure it out.
Have speedo on GPS for letting me know an approximate speed to fall back on.
meanmx
Postby meanmx » Sat Jun 23, 2007 6:55 pm
You'll find the gps will be jumping all over the place as well unless you warm up your leg muscles before you get in the car instead of waiting until the heater warms them up. In this sort of weather it's called shivering :lol:
Ben
2014 VW Mk7 Golf R
Stu
Postby Stu » Sat Jun 23, 2007 7:35 pm
LOL
Richee
Postby Richee » Sun Jun 24, 2007 9:57 am
Has this sort of thing happen in the '03 Tribute and a new battery fixed the problem.
Mazda Tribute - its a boat
Coming - Jayco Eagle wind up camper - woo hoo
Ex cars 2007 NC LE Radiant Ebony, 1990 Eunos Neo Green LE
Garry
Postby Garry » Mon Jun 25, 2007 9:42 am
You could try looking at the wiring at the gearbox. The speedo is electronic and the speed sensor is on the gearbox. The plug could be loose or if your car has had the clutch replaced the wiring may not have been secured properly and it could be flapping around causing an intermittent fault.
JSE
Postby JSE » Tue Jun 26, 2007 6:30 pm
my speedo does the same thing Stu. From 30-70kmph it jumps around heaps (although still pretty accurate). Just never was bothered to fix it...if you find out the problem post it up :D
Stu
Postby Stu » Wed Jun 27, 2007 2:11 am
JSE, I will return and post solution once I know.
Have been working out at a clients site recently, and they have the most ridiculous speed hump that I can only go over at crawling speed. Now wondering if I did any damage bottoming out on it.
Stu
Postby Stu » Tue Nov 27, 2007 12:13 am
Think I have fixed this problem.
The problem went away after I took some dodgy LED globes off the car. Just a though but maybe the speedo wasn't getting enough current?
Juffa
Postby Juffa » Tue Nov 27, 2007 10:09 am
Stu wrote:Think I have fixed this problem.
Hi Stu,
Interesting, I would have thought that LED globes would use less current. There has been a number of recent posts on the big forum around the in-correct fitting of bulbs which caused weird things to happen.
J
mr_rotary
Postby mr_rotary » Tue Jan 08, 2008 9:27 am
Mine does the same and I am yet to find two minutes to fix it. I have a link from the big forum that tells you how to fix it however I don't have the link handy on me right now. Will post it up later.
